Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Upon startup ...new season. Pumpstarted but when full circulation started pump shut down and seemed overloaded
  • Hayward Master
  • 1,358 Answers
Well..you can start by blowing out the back of the motor with compressed air" where the wires go into tthe back of the motor cover" there is whats called a start switch there ! if this fails to fix it search for your local pool pump motor repair guy in your area and bring it to him for free testing.. CLICK HERE HOW TO REMOVE MY PUMP .. LAST prime the pump and make sure the filter needs to be clean
Posted on May 27, 2011
  • randman77 May 27, 2011
    Thank you .....but motor was ka blewie, just finished installing new one.......thanks again.
I have a New Waterway tiny Might Pump on my spa. It seems to trip its internal overload every
This is an indication of a bad motor. You will need to change the pump.
Rod
US Parts Center
Jun 29, 2013 | Waterway Circulation Pump Tiny Might 120v...
My Husky Pressure Washer bogs the motor down immediately upon start.
Rebuilding the pump is not easy. Did you use the right seal drivers? Lube the seals when you installed them? Use a torque wrench? But a valve in backwards?
May 04, 2013 | Garden
Blower start up problem
The motor is bad. It is overheating and shutting down on thermal overload. You need a new motor
Jun 24, 2017 | LG LWHD1200FR Wall/Window Air Conditioner
Briggs engine stutters upon startup
might have unseated a valve check the compression it is good at 100 lbs min to run is 90 lbs thats bad
May 29, 2012 | Briggs & Stratton Garden
Pool pump shuts off after a couple of minutes and seems to be hot
You problem could be one of several things. First, pumps have a thermal protection switch that shuts the pump down when overheated. You could have rust after only one season that overheats the pump and it shuts down. The switch could be bad. There could be an electrical issue when running it on a long cord of the wrong gauge. Plug the pump into an outlet without extension cord and see if it makes a difference.
Apr 18, 2010 | Pool & Spa
Dryer won't start or it starts and runs for a minute or two only
When it does start does it seem to hesitate or have a louder hum than normal upon startup? Please write back with the model number and I can further assist you. The vibration from the dryer being on could be disconnecting the power behind the plug in the wall. turn off breaker to that dryer and make sure connections are good to the outlet...I have seen this happen before. If it seems slow to start when it does start and make a hesitating humming sound before it gets going your motor maybe going on overload and shutting off. Therefore you would need a new motor....please let me know...
May 12, 2009 | Whirlpool LER5636P Electric Dryer
Ruud heat pump initial startup,both guages shoot to over 300 lbs
Brand new install...did you open the refrigerant lines to release the refrigerant?
Apr 01, 2009 | Heating & Cooling
Boiler shuts down repeatidly
i think you will find that instead of modulating as demand requires the boiler is overheating and then re operating after the safety thermostat has operated.
i wilud put some de scaler into the main heat exchanger circuit or add it to the radiators and let it circulate for a while.
also make sure the pump is operating properly to ensure proper water flow.
Nov 17, 2008 | Water Heaters
Arking and noisey compressor startup. can smell a burning odor after restart
sounds like a bad overload relay assy for your compressor, its attached to the side of our compressor assy if that is what making the noise heres the part number 12002784. but if its burnig and arcing enought o ruin the compressor terminals you may need a new compressor, and depending on when purchased may or may not be covered. new overload relay comes with new compressor if needed
Oct 26, 2008 | Maytag MSD2756G Side by Side Refrigerator
Kandalf LCS liquid not going through the loop
This is most likely an issue with your pump or the water pressure in the loop. Sometimes gravity or a short-circuit in the plumbing can cause water to stall at certain points.
If the pump motor is not vibrating, then that's an immediate indication that your pump is either defective or you have not installed it correctly.
Check to make sure it's got power, water, and sufficient grip on the tubes. If these are all fine, look at getting a replacement for your pump.
Oct 15, 2008 | Thermaltake Kandalf LCS VD4000BWS ATX Full...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
