Question about Broderbund The Print Shop 23 Deluxe
I have tried to install Print Shop 23.1 Deluxe a dozen times & only parts will install. I am using Windows 7 Pro. I have loaded it totally on another workstation that is the same as this one & it load Ok. Parts of the Opening screen is blank & the other Pop Up Screen (at 1st opening program) do not een exist. I have tried every thing that Broderbund has asked me to & still won't load sucessfully.
    Top Expert:
  • Broderbund Master
  • 76,649 Answers
You need to contact the product staff for that software, we can't fix this.
Posted on Jul 19, 2017
proartya8765
  • 581 Answers
SOURCE: Print Shop 2.0 Deluxe will not load.
Have you tried installing them in Compatibility Mode? If not, look in
Vista's Help
& Support for how to try this. If that doesn't work, you can
try installing them as Administrator by right-clicking on the installer
executable and choosing "run as Administrator".
If none of that works, I'm sorry but you'll need to update to a current
version of the program that the mftr. says will work in Vista.
Posted on Jan 30, 2010
  • 154 Answers
SOURCE: does not want to install Platinum print master version 18
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP2_bing.gif, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution2_bing.gif to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio2_bing.gif button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
Posted on Apr 01, 2010
  • 4 Answers
SOURCE: wasn't prompted to load image disc print shop pro deluxe 23
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Posted on Jun 04, 2010
SOURCE: Purchased Broderbund Print Shop 23.1 Deluxe. Two
Yes, otherwise you have to manually insert the Art disc every time you want to use the Art & Photos.
Posted on Oct 12, 2010
muntejaya
  • 10421 Answers
SOURCE: I cannot save as PDF
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__0ojjd43
Posted on Feb 26, 2011
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
Can not install Print Shop Pro Publisher Version 21 will not load on Windows 7
You can try setting it to run in compatability mode.
Right click on the program Icon
Click properties
Then click compatability tab
Check mark Run this program in compatability for
Select windows xp in the drop down list.
Click apply then OK
Try running the program
If this does not work try
Right clicking on the icon of the program and selecting run as administrator.
This program version is not supported by Windows 7 so if this does not work the you will need to upgrade to Version .23 instead of .21
Jul 05, 2011 | Broderbund The Print Shop 21 Deluxe Full...
I have the full version of print shop deluxe22 and it won't let me install it on my hp laptop HP G71-442nr Notebook, Running windows 7
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
May 25, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
Installing Print Shop 21 in Windows 7
Print Shop version 21 Deluxe is not compatible with Windows 7. You have to use a newer version 23 which is compatible. This is due to software compatibility with Windows 7.
You can check forcompatibilites issues @ Windows 7 "software & hardware" compatibility center
Mar 14, 2011 | Broderbund The Print Shop 21 Deluxe Full...
Printshop 20 deluxe will not install on computor has windows 7
Yes, it will NOT work on Vista or Windows 7. I had to upgrade to PS 23 on my computer. If you have 7 Professional or Ultimate, it is backwards compatible to accomodate older software. If you have Home Premium, it will NOT work on 7.
Good Luck.
Jan 03, 2011 | Broderbund The Print Shop 20 Deluxe for PC
Just got a new windows 7 and wanted to use my Print Shop 22 Deluxe but says certain parts are not compatible. What do I do?
just got a new computer with windows 7 and wanted to use my Print Shop 22 deluxe but says certain parts are not compatible , What do I do ?
May 20, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Wasn't prompted to load image disc print shop pro deluxe 23
Mar 19, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Broderbund The Print Shop 23 Deluxe  Logo
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
