Question about Grilling
My gbc heatseal h300 wont feed paper. - Grilling
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
Posted on Oct 31, 2011
    New Friend:
  • 18 Answers
The GBC H300 was last manufactured in 2010 and has been discontinued as an "obsolete" product.
If an H300 failed under valid warranty, GBC would replace it with a similar model and would not repair the broken H300.
Parts were never stocked by GBC for the H300 since it was considered a "disposable" model. However the H300 was apparently renamed from the GBC DS-125P which did have parts available at one time.
GBC replacement part #26700056 is used on both the H300 & DS-125P but no longer stocked or sold by GBC when I checked during 5/14.
Both GBC Customer Service and Parts departments were unable to see online if this 18T bevel gear part was used in other GBC laminators and is currently available.
Apparently the original DS-125P replacement part price was $19 when available...
Posted on May 21, 2014
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
How do I put a GBC Heatseal H425 laminator back together?
You might contact GBC directly and request an assembly diagram
Jul 14, 2017 | Gbc Office Equipment & Supplies
The laminating paper started coming out rippled half way through a roll. Do you have any suggestions?
Usually caused by uneven pressure / heat. If this has a lot of use look near ends see if you have small ridge that goes around roll. Would be where edge of paper would be. If you do your pressure roll is worn and no longer provides constant pressure feed.
replace rollers.
Sep 23, 2016 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Laminate Film Disconnected
Un-coil the lower roll and feed it through by hand.
Dec 06, 2013 | Gbc HeatSeal H425 Laminator
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
I have a gbc heatseal h425 laminator and it wont turn on. Is there a fuse inside the machine that needs to be replaced
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Dec 23, 2010 | Gbc HeatSeal H425 Laminator
Grilling Logo
1,510 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
