My sound hardware don't works even when I've installed the drivers... so, what can I do?
  • 23 Answers
You can check or updates on the driver, also, check in the audio options,sometimes the audio device is disabled from there even after installing the driver. How to do so depends on your Operative System,but if you have the speaker icon on your tray you can right-click it and select the "playback devices" or "recording devices" depending on which is not working. Click on the device that seems to be disabled and click the "Properties" button. Somewhere in that window (usually in the lower area) there will be a drop-down menu that has the options of "use this device (enable)" or "Don't use this device (disabled)" pick the first to enable the device that is not working.
Posted on May 26, 2011
Gateway 3501643 profile 4 network card not reinstalling
Usually, the networking hardware is the easiest to set up for drivers. If you know the chipset maker and model, you should be able to go to the maker's website and get drivers. If not, and you don't want to open the case to look, then go to http://www.belarc.com and get the advisor utility, it's free. It should identify your hardware and you can do a google search from there.
Oct 31, 2012 | Computers & Internet
I'm using a Toshiba L505-10W. recently i've installed windows 8 consumer preview. my wireless doesn't turn on and the flash cards doesn't work either. realized that even my bluetooth d
The drivers for the hardware don't exist for windows 8. You need to format. turn on holding the 0 key. follow steps to set to factory defaults, save your pictures and documents first cause this will erase them.
Jul 01, 2012 | Toshiba Computers & Internet
My Webcam Model 156 does not work on my computer. I also don't have a webcam software. what shall I do ?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 16, 2012 | PC Concepts 300K Webcam
Sound problim
you need to install the driver of your sound card.
this is the 5 Driver Finder (Online) :
1. http://www.all-driver.com
- Search for all aviable Driver
2. http://devid.info
- Search Driver From Hardware ID (you can See Hardware ID from Computer Management > Device Manager > Propeties hardware you've Need the driver > Details
3. http://www.driverguide.com
- Search Driver by Model Name or number
4. http://www.driverstock.com
- Search Driver by type and the producer
5. http://www.nodevice.com
-Seacrh driver from Categories or Companies
try it,and don't forget to rate me if this post helpfull.
thanks be4
Jan 17, 2012 | Computers & Internet
My problem is the same as the rest of these, My T9100 has lost the driver for the Yamaha AC-GX sound device. It worked find until I installed XP SP2, I've been to various forums and followed...
The 9100 series are famous for this problem, and it's more than likely hardware related and not driver related: the connector on the motherboard (where the sound card connects to) is probably loose - so it's not seeing the sound card (or only seeing part of it). Problem is probably caused by chassis flex over the years, and it's pretty common.
Solutons? Dunno... I've fixed about a thousand of these but over the years, about 1 out of 5 had the same problem recur, and I'm tired of fixing these things. Cheapest workaround? Get a cheap USB sound card and a cheap set of laptop speakers (cost me about $4 total) - a little cumbersome, but it don't cost anything....
Sep 19, 2011 | Toshiba Tecra 9100 Notebook
I have a problem with my computer speakers because they don't work & i've even tried to to use headphones & even they won't work so what should i do
It sounds like it may be a driver issue, but first, I'm assuming you check the volume controls on Windows to make sure it wasn't muted or anything. Yeah? Good. So let's get to the drivers. I actually have a tip here that will show you how to do this. Check it out: http://www.fixya.com/support/r9307246-fix_sound_installing_new_driver Hope this helps!
Aug 27, 2011 | Computers & Internet
No sound
You have to install the audio device drivers for the audio device to work. In case you don't have the installation cd here is a link for direct download from the official site. Choose your op. system (win XP, win 7 etc) and proceed to download and run the proper file.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 01, 2011 | ASUS P5GC-MX/1333 Motherboard
I hv mindows 7 installed n so no sound coming
try to find the sound drivers for your sound card. Make sure the drivers are for Windows 7
Jul 12, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I cant install my sound driver.. conexant just says not reconized and the other one just dissapear mid-installed
Usually, this means it's not even recognizing that it's on board. Easiest thing i can tell you is go to control panel - system - device drivers - go down to sound, modem, and delete the entries. Then re-start your system. See if windows finds the hardware. If it does, then install using your cd. Don't let windows install it. Just close those boxes. Many sound issues are modem related. Most modems require the sound card and that's usually the issue.
Jul 10, 2011 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
