Question about Vacuums
How do i disassmeble this unit? something stuck in motor
  • yadayada
    yadayada May 26, 2011
    You have not provided the make or the model or even what this is.
Hi , I have a Karcher wet and dry vacuum and lately it makes a very loud screaming/howling sound when in operation , why is that and is it fixable ?
The motor has a fan on the top to cool it off and it is usually pressed on the shaft, they can come loose. The impellor on the motor may have come loose, there may be something stuck in the impellor area. Some of the motors have pressed on parts and cannot be repaired.
Feb 05, 2018 | Karcher Vacuums
How can I stop the squealing noise in the motor on my Sanitaire wide track commercial vacuum? It's making a squealing the minute I turn it on
Is it the motor or the brush roll? Remove the brush roll and belt and see if it still squeals. If not clean or replace the brush roll and get a new belt. Inspect the fan to insure there is not something stuck in it. If it's the motor you can try to clean it, make sure there is not something stuck in the motor causing the noise.
Jan 23, 2017 | Vacuums
String stuck in vaccum cleaner
the question is how did the string get past the filter to get to the motor
vacuum motor units are sealed so consider a new unit
Feb 22, 2018 | Vacuums
The pump motor hums but wont start
unplug machine and see if you can turn the brush in the head. if the brush can be turned then the motor is probably burnt out. if the head is hard to move then there is something stuck in there preventing the motor to turn. there is usually a belt from the head to the motor.
hope this helps
Jul 12, 2011 | Vacuums
The vacuum has started making a much louder noise. like something is coming apart or is stuck/clogged. Noticed the fan type blade has several cracks, some bigger than others. could this be the problem?
Yes, this is very likely. The fan is made of plastic, because a metal fan would be so heavy that it would make the motor burn out unnecessarily fast. Sucking up things like loose change, pebbles, screws, etc. can crack the fan, and unfortunately this requires the front part of the motor to be disassembled. I'm pretty handy with Kirbys but I wouldn't attempt this type of repair myself. Best to leave it to a professional.
Do be sure to remove the em-tor unit (the plastic part that attaches to the blower in back) and check to make sure no large items are rattling around in there. Just unhook the bag clip from the handle, grasp the em-tor unit at the base and turn firmly but gently. When it pops off, all the things that were too heavy to get sucked upward into the bag will fall out. This might help, but it is not recommended to run a Kirby with a damaged fan. It is bad for the motor.
May 24, 2010 | Kirby Heritage II Vacuum
Won't turn on. How to reset the fuse
Kirbys have no fuses. You either have an electrical problem, physical blockage, or the motor is bad. Can you turn the drive shaft freely when the brushroll head is removed? If not then you have something stuck in the fan chamber or the motor is bad. If it turns freely then it is most likely an electrical problem. Kirbys motors can take a lot of punishment so dont get rid of it. They are normally very inexpensive to repair.
Dec 19, 2009 | Kirby G4 Bagged Upright Vacuum
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
Sharp ec-14twt6 won't start
if the motor spindle spins easily when turned by hand, the motor brushes need replacing. if it doesn't, either something is stuck in the turbine, or the motor is siezed. if the motor is siezed, it needs to be replaced.
Jul 22, 2009 | Sharp EC-S2365 Upright Vacuum
Serger motor won't stop running
the switch is stuck in the on position.replace the switch.sounds like you have something jammed up in the motor.openit up to get to the motor and see whats in there
May 04, 2009 | Vacuums
Motor is noisy like there is something stuck in it. I am looking for the service manual so I can see how to take it apart/
Hi Generally modern upright vacs don't have screws that you can undo to get into the motor and most Electrolux/Eureka models have sealed units. I suggest looking at the sole plate where the roller brush is, check for anything clogging the main dust channel and then remove the hoses. Also take out the filters and give them a good clean, washing them are good but you must let them dry (or put in a low temp tumble dryer in a pillowcase with a towel) out.
You'd have to check out Eureka's customer services for an imploded service manual. Check on their website if nothing else works.
Mar 27, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
