Accoustic soloutions dvd160rw300 dvd recorder. Turned itself off, only the main power light on, no time displayed or functions working, wont even power on when power button depressed, any ideas
Same thing happened here... No idea what to do! Hope there's a solution :/
Posted on Aug 30, 2011
Sony RDR-HDC100 will not remain operating and turns itself off
follow this step:
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
    However the power supply can be faulty,some resistor,capacitor, diode or IC . see the block attached .If you do not have skill for electronic, go to the repair shop.
    God bless you
Feb 09, 2013 | Televison & Video
Lg dvd recorder wont record get message "service unavailable or scrambled"
It isn't programmable, once you have it wired to the TV you select function display and it should program itself if properly connected.
Sep 01, 2012 | LG Televison & Video
Dvd recorder in standy wont work - blue standby light showing!
The main power supply board has the fault. It might be replaced. It is best to replace as card basis, rather than making 'surgery' to it.
May 30, 2012 | Televison & Video
How is the time/date stamp displayed on a copy
The time/date is 'stamped' onto the video during recording. The time/date stamp function can be turned on or off in the setup menu. If it was 'on' during recording, it will be displayed when played back. If it was turned off, it will not be seen on the recording.
Jul 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi, Have just purchased Samsung DVD HDD recorder (DVD-SH855). Everything works great except the timer recording. When i schedule a recording, the system wont start recording. The recording light flashes...
I had the same issue. It turns out that the recorder has to be switched off otherwise it won't record. The unit will power itself on at the scheduled time and record your program. It doesn't make any sense to me why this would be a requirement but it solved the problem for me.
Jul 06, 2008 | Televison & Video
LG DVD Recorder "Unknown disk error"
I have the same problem with my LG DVD player, with some discs saying disc error all of a sudden. I solved the problem by cleaning the lens of the laser very gently. The player must be opened to reach the lens. It is very important to get the plug off the mains so as no electricity supply is in the DVD player. The lens was cleaned by using a soft dry cotton bud (those used to clean the ears). NO solutions liquids etc. were used. Well, till now the problem has been solved. The lens was full of dust which come from the static of DVD's. The rest of the inside of the DVD was generally clean.
Mar 17, 2008 | Televison & Video
Please wait
try to clean loading sensors
Jun 03, 2007 | LG RH-4820 DVD Recorder
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
