Question about Watches
CANNOT UNLOCK MY WATCH - Watches
I got my unlock code from the carrier but my galaxy s3 still wont unlock. What can I do?
https://www.youtube.com/watch?v=hmQwEipEdFA
watch this video. you already have your unlock code so ignore the process until he explains how to put in the unlock code. Make sure you do it right because i think you only get 4 attempts at it.
Sep 20, 2014 | Samsung Galaxy S III S3 16GB AT&T
Can't unlock the touch screen to set KC1850
I'm having the same problem. Has anyone figured it out - how to unlock the screen.
N.B. It worked previously, then stopped.
Dec 25, 2013 | Kenneth Cole New York Mens KC1850 KC-Touch...
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
How can I resize a citizen watch with an expandable band? It's a little too big. The owner's manual doesn't tell. Thank you-
If you look carefully on the inner side of expandable bands, there's usually the removable links of the band near one or both ends of the band.
These usually have arrows indicating which direction the locking pin/tab slides to unlock and allow removal.
If you're careful, you can unlock them and remove one or two by using a small screwdriver. A very inexpensive alternative is to find a local watch repair shop and have them resize if for you while you wait. They've got the mini-tools and it's usually very reasonable (around here, there's a couple chain grocery stores that have watch repair kiosks inside..great alternative and cheap).
Nov 17, 2009 | Citizen Silhouette Eco Drive Gold Tone...
How do i unlock my polar f6 watch?
Press and hold the LIGHT button (top left button) to manually unlock. It's on page 23 of the manual. (Assuming you're talking about keylock.)
Feb 02, 2009 | Polar F6 Wrist Watch
Watches Logo
140 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
