Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the high/low settings on the carb to get me started with the 181 husqu. se
  • 608 Answers
Hi, low screw 1 and a quarter, hi screw 1. Regards Phil.
Posted on May 26, 2011
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
Feb 09, 2017 | Ryobi Garden
ADJUSTING HIGH AND LOW ON A CARB FOR A STIHL FS 45 WEED EATER
Hi..in general i always set the high and low screws at 2 turns out from a complete stop..and please dont tighten the screws too tight..it will bend the needles...I think it will..or should run at them settings...as far as the gas out of the engine..it is or has a problem with the carb...did you remove the carb...? Also try starting it with only starting fluid for a very short time..this is how I check to see if all else is ok..spray it in the carb in take...
May 05, 2016 | Stihl Garden
What is the initial carb settings on the carb?
screw jets in untill they bottom out slightly then--
high jet one full turn out
low jet one and a half turns out
slight adjustments might have to be made once unit is running
hope this helps
Sep 04, 2015 | Husqvarna Models 181, 281, 288xp
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
Husqvarna 181 se wet plug wont start -low is 1/4 turn -high is 1/4 turn- checked diaphgram - checked & cleaned carb
i would remove the muffler and clean the screen inside they build up with carbon and more so when you have carb problems
Aug 12, 2012 | Husqvarna Chain Saw Handle Models 181 281...
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
How to adjust the low and high settings on the carb
With all the new EPA guidlines on emissions there are many new type of carbs.The older type was easy, If its a walbro or zama brand and it has 2 adjustment screws as well as an Idle speed, preset the low and high at 1.25 turns out from set, start the saw, run it to full throttle,adjust the high speed needle counter clockwise untill you hear the engine start to flutter. You want to year the flutter about once every 4 seconds.then let it idle,adjust the low speen till it runs smooth then make it 1/8 turn richer. Many of the new carbs require special tools to adjust, not brain surgery, just to keep the air cleaner..
Oct 27, 2009 | Poulan Garden
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Will not tick over how do i set up the carb for this and normal running.
Most carbs are the same. Close both the high and low needles. (Note: Do not overtighten, you can damage needle.) Open them up 2 full turns. Start the engine and let it warm up. May be a little tough to start if you have removed carb and rebuilt. With engine running pull throttle to full capacity. Now close the low needle slowly, listening to the engine. When it starts to get lean you will hear the rpm start to go back down. Make sure you stop at the most optimum setting. At this point open the low needle 1/4 turn so as not to have too lean a mixture. Please note that the engine must be warm in order to get the right setting. You may have to do this a couple of times to get it right. Then move on to the high needle and do the same thing. Once you set both needles it should be fine.
Sep 09, 2009 | Makita DPC6410 64cc 12" Power Cutter
Need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Jan 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
174 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
