Question about Samsung Cell Phones
I was in the bath, and my phone was on the shelf, well away from the bath. i went to pick it up, and the water gotten into it! i can only get the red button to work. i cant view message or call anyone. please help?!
It's most probably dead. Try removing the battery and leaving it somewhere warm for a day to completely dry out, you might just be lucky.
Posted on Aug 16, 2008
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Hi. I have a DeLonghi 3107 radiator-type heater, g...
Personally I would throw it away. those radiator type heaters were OIL filled when new ,not water filled
May 20, 2010 | Heating & Cooling
Hot water on bathroom faucet won't get hot only luke warm
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
Apr 12, 2010 | American Standard Bath Faucet Ceramix...
I dropped my samsung E840 phone in the bath 2days ago and the screen went black but the phone still lit up...the screen is now back to normal but goes black every now and again and the numbered buttons are...
Recent phones dont agree with water to much, but what you can do is pull it apart and spray it all with a electric cleaner, but if you have insurance on your phone that would be the best way to replace it, warranty wont cover it. you could try to hard reset it but most likely wont work still
Sep 27, 2009 | Samsung SGH-E840 Smartphone
I have a motorola razr v3x phone, problem with water damage
I dropped my in the bath tub giving my little girl a bath. I pulled the back cover and battery out and sat it upside down, back faceing up, under a lap and turned it over every hour. The next morning put the battery in and closed it up, no problems - till the next time it went swimming and had to repete the process.
Sep 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My Kohler whirlpool started on its own with no water in it. We turned it off with the switch and it hasn't happened again. Is there a danger of it starting a fire if we are away from home and it does it...
Most Kohler tubs have a water sensor or water level sensor. Is this an air bath tub (holes in the floor)? or a jetted tub? If it is an air bath, the tub will purge after using it 15 to 30 minutes ater it is drained. If it is programable it will come on every 24 hours if it has been programmed. If it is a jetted tub, there may have been water on the sensor and caused it to start up. If it is a single on/off button the switch could have gotten water and caused it to start up, or there is a problem with the control box. It usually will not start a fire if it comes on, most of the newer pumps have run dry seals. If you leave the house for vacation or weekends, I would advise unplugging the tub or turning off the breaker.
Aug 28, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Water damage to sony ericcson k770i
http://www.fixya.com/support/r3771170-phone_water_damage
Mar 04, 2009 | Sony Ericsson K770 Cell Phone
Cell Phones Logo
23 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
