Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Remote control stopped working on Mitsubishi WS-65615. The front panel controls still work, is there any easy fix for this?
  • 1,476 Answers
Sesontcket,
For the cost of remotes it is not worth trying to fix them. You can get an exact replacement remote at http://remotes.com/ or probably for less a universal remote at any Walmart or Target for less than $10.00. The All-In-One brand seems to have the most features and is the most reliable.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 26, 2011
Mitsubishi WS-65615 Works great except I can't
The input selection circuit to your TV should be checked. It is not a user repairable work. Contact any technician. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 08, 2013 | Televison & Video
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
How do i take the parental code off of my Mitsubishi WS-65615 65" TV?
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jan 07, 2010 | Mitsubishi WS-65615 65" TV
Mitsubishi 65807 won't power on
hello it's possible the glass fuse may blown inside the tv take the back off and check but make sure the power's off
shaun
Oct 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Power light flashes.
The dm board is located inside the vertical metal case on the left side when viewing the tv2.gif from the back side.
Have you tried disconnecting the front panel on the tv? There are 2 plugs that go into the board and sometimes there is a faulty switch on there which causes your problem.
Aug 20, 2009 | Mitsubishi WS-65615 65" TV
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv problem
hold the menu button down for 10 seconds tv should power up you will have to turn off front panel buttons on menu hope this helps
john
Jan 24, 2008 | Mitsubishi WS-65615 65" TV
No control of WS-65511
The following solution has been posted in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 22, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
