Question about Fedders D Chassis AED24E7E Air Conditioner
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
    Genius:
  • Fedders Master
  • 1,033 Answers
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
Posted on May 26, 2011
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
How can I add freon to a crosley ac unit, it's
Unplug the ac unit and let sit for 30 minutes to a hour..... Wear safety goggles and gloves... BE CAREFUL IF YOU ARE NOT LICENSED TO DO A/C SERVICING!
Buy a saddle valve and attatch it to the low line, suction line which should be connected to the compressor....
Buy a set of guages and attach the guage hose to the saddle valve and see if the pressure reads out correctly (the psi pressure level should be written on the side where the model number is and if it's low or empty, then continue with the refilling process...
Buy a jug of R22 ac freon and fill it to the correct low psi...
I recommend that you change the thermistor first to see if it's bad and causing the problem...
Be careful...
Be careful...
Be careful...
Be careful...
The lines are under pressure!
Hope this works out for you...
May 20, 2013 | Heating & Cooling
Add coolant to a fedders a3t12f2al 12000 window ac
You can recharge the compressor with R134a refrigerant gas, but not with coolant. But, the compressor will have to be purged of any existing refrigerant gas, before recharging with new gas.You shouldn't mix old with new, because depending on the age of the unit, it may still have Freon in it. Freon has been banded by the EPAand doesn't mix with the new gas.
Hope this helped answer your question. Thanks for choosing FixYa.
Aug 16, 2011 | Fedders Heating & Cooling
My air conditioner delivers cold air only in spurts. It then goes into fan mode for a few minutes, then to cold air in a few more minutes. It is over 100 degrees outside and the inside of the house is 85...
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up
The unit will need to be recharged or replaced...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 27, 2010 | Fedders AED24E7F Wall/Window Air...
CAN I ADD FREON TO MY FEDDERS AC ? it gets cool for a few mins then compressor kicks off ! does it sound like low on freon , ?
Take the front cover off and make sure the copper bulb is not touching the fins. Bend out a distance of 1/2 inch
Jun 15, 2010 | Fedders D Chassis AED24E7E Air Conditioner
AC ran for a couple of hours and started blowing
If it is icing over, it is low on freon. You might have a freon leak if the system is relatively new. It will take a licensed tech to check, fix leak and recharge.
Aug 25, 2009 | Fedders AEQ07FBG Air Conditioner
My ac does not work properly when I add freon the ac will work well for about 5 minuted then will blow warm air hoping some one could give me an idea what might be wrong, ie what to replace to fix it.
does the compressor keep cycling on and off ? if so then it is low on refrigerant causing the cycling, sometimes you have to bypass the compressor pressure switch to stop it from cycling long enough to get enough refrigerant in the system, but of course you need to check for a leak if you are trying to recharge the unit then add a refrigerant with dye solution in it to locate any leaks, note leaks and then evacuate system amd rapair the leak source and then draw the system down add the proper compressor oil or refreigerant with oil in it. you may want to have a qualified AC repair facility do this , so they can properly evacuate and recover the refrigerant material... thanks , please rate my help...
Aug 06, 2009 | 1994 GMC Sierra
How do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Jun 15, 2009 | Fedders AEQ07FBG Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Fedders D Chassis AED24E7E Air Conditioner Logo
325 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
