Question about Vacuums
Pfaff quilt expression 4... the thread snipper blade has come out during cleaning, how do I put it back please. It does not mention it in the booklet that comes with the machine. Many thanks, Bobbie
2 Suggested Answers
  • 11 Answers
SOURCE: I cant seem to find
I searched the web but only found stuff for sale and the Pfaff web site di not show any link to manuals. You might try joining this group on Yahoo. I'm not a member so I can't say this group will have a manual but since they are devoted to the old Pfaff sewing machines they may have it. I think you may find a lot of support at the very least. http://groups.yahoo.com/group/oldpfaffpforum/
hope this helped
Posted on Feb 04, 2011
Thread on top keeps breaking
Buy a pressure pack of 'dust off' open the machine and blow out any lint. Check oil for level and clecleanliness.
Mar 02, 2014 | SewShop.com Gammill Vision 18-8
Hi, I have a silly question. How on earth do I thread my Brother Xr-65 sewing machine?!! I have misplaced the users manual during my recent move. It seems to take thread a little differently than my...
The XR-65 and the XR-65T are the same except that the T indicates the sewing machine was sold with the Quilting Table and some accessories for quilting.
To thread the sewing machine, first lift the presser foot and use the handwheel to raise the needle to its highest position. The thread take up lever should be at its highest point. Place the spool of thread on the horizontal pin secured with the appropriate cap. Make sure that the thread comes off the spool from the bottom front, (Also check that the catch (for holding the thread when not in use) on the spool is at the back of the pin.) Then bring the thread to the thread guide at the back of the machine then down past the reverse lever and back up the the thread take up lever. Wrap the thread around the take up lever so that it slides into the slot and then goes through the hole in the take up lever from right to left. Bring the thread down again and place it behind the guide above the needle. Then thread the needle from front to back.
Brother has the manual available for download: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf . See page 31 (43 of the PDF) for the pictures of the upper thread path.
I hope this helps.
Jul 29, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I have an expression 2038 and the stitching has suddenly changed so that the top stitching is quite good but the underneath is loose. I have the tension on 4 and have a new straight needle and good quality...
If the bobbin thread is too loose, remove the bobbin spool AND carrier.Thread the thread through the tension clip on the holder in the normal way. Hold the thread and lift it. If the bobbin slides down, tighten the small screw 1/8 turn clockwise, until you can lift it with little or no sliding.
May 07, 2011 | Vacuums
I cant seem to find a manual or even a threading diagram I am disabled so $$ is very hard to come by I was given the pfaff 130 machine just no manual please help. Thank you Karen V
hope this helped
Feb 04, 2011 | Vacuums
How to put bottom blade of blender back after cleaning
Drop blade in from the top.there should be a notch that blade fits in or it should screw into bottom piece that drives the motor of blender
Oct 21, 2010 | Vacuums
Pfaff Hobbylock 756 User Manual
On the link below You can get the manual you need #39.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Pfaff.htm
That is the only way to get the manual.
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 12, 2010 | Vacuums
What needle and thread would you use for sewing marine vinyl when using a pfaff 130
I have heard Pfaff 140 needle with V-92 or V-138 thread is the way to go with marine vinyl.
I hope that helps.
May 02, 2010 | Vacuums
Vacuums Logo
97 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
