Question about Mintek MDP-1020 Portable DVD Player
Power keeps going off... I have tried taking the battery out, moving the cables....I smelled a little burnt, so thinking some wire or componet has been burnt internally....I think I need to send it to someone to fix?
  • Mintek Master
  • 508 Answers
The short answer is, yes you do need to send it off to a repair centre. Any kind of burning smell in an electrical appliance (regardless of the power source) can be very serious, even dangerous. The fault is most likely to be in the unit's power supply circuit (it means a high DC output has been applied to a circuit that is meant to operate at a lower voltage; hence the burning smell) several components may have contributed to this. The beauty of workshop quotes is that you can choose to accept them and go ahead, or if the cost is likely to be more than the retail price of a brand new unit, decline, and buy a new player - but only as a last resort - get the quote first. A qualified technician will be able to assist you further in this matter. Up to you.
I do not recommend that you attempt to operate or plug the unit into a wall socket while it is in fault condition. I don't believe replacing the battery (if available) would make much difference.
Posted on May 27, 2011
LG 47 LS 4500 LED LCD burnt power board
Hi Keith,
First try to replace your power cable if it seperate from your TV and use another power socket to cofirm your cable is good and power socket. If your power cable is attached to the TV then just take the set to repaire centre and get it fixed.
Regards
Ashwin
Jan 23, 2015 | LG Televison & Video
I have a Jensen JCD2010 in my travel trailer. There is power to the unit, but there is no display. Nothing happens when I push the buttons and dials. The display is blank. Could it be that it is due to me...
It should have two power inputs.
One is connected to the battery, uses very little power to maintain presets, maybe an LED also. The other is via ignition switch.
My Jensen 2620 requires both inputs to function.
May 27, 2014 | Jensen JCD2010 AM/FM/CD Stereo
My Eee 4g surf netbook won't charge at all. Upon turning it on, it runs for a second, then shuts off due to a lack of battery power. The charge cable's light is also not turning, so that may
I think your DC Power Jack is bad. The DC Power Jack is where the power cord plugs into the laptop. If it is bad, then a good power cord cannot charge the battery, nor can the laptop turn on once the battery is drained.
You say it smelled burnt, that might mean it took a power surge. I always tell people that before your plug the power cord into the electrical outlet on the wall to remove the other end of the cord from the laptop. That way if you get a power surge you will only damage the power cord and not the dc power jack or motherboard.
Anyway, take an ink pen and push it into the dc power jack and see if there is some movement. The little pin or the casing of the jack should not wiggle.
The DC Jack is soldered onto the motherboard. To replace it you will have to take the laptop apart, desolder the old dc jack and solder a new jack onto the board. Sometimes the DC Jack sits in a slot rather than being soldered. The palmrest and bottom case helps to keep it in place. This type of DC Jack usually has a cable harness that plugs into the motherboard.
Apr 02, 2012 | ASUS Eee 4G Notebook
Microwave smells like burnt wire
When you smell something wire is burnt..The first that needs to check is the inside wiring.You need to open the back portion of your oven to further see whats the problem behind..You can unplug from the source and using a MULTITESTER.Check both terminals setting yuor TESTER to OHMS value.If the TESTERS pointer moves a little it means its not short-circuited ans if otherwise moves to its maximum amount it means it is short-circuited that needs to be repaired..Wiring might have been burnt.If you gonna continue using it it might lead to further complications of defects.Try to check the motor that turns the turntable..check the heating filament.hope this helps.
Jul 07, 2011 | GE JE1640 Microwave Oven
My Speed Queen dumble dryer smell like burning wire
HI....Does the MOTOR works or rotates.If it still heres no problem with that...if you smell something bad on your machine there something wrong with the motor wires coil..possibly overloading can cause problem with the motor..motor will produce more power beyond its capacity then its coil becomes hotter that gradually burnt the coil.You can check by removing the back cover of the machine.Unscrew it properly.locate the motor as well as the shafting..If yuo smell something bad with the motor possibly coils got burnt. you can check both ends of the motor terminals using a MULTITESTER .Unplug first the machine set the MULTITESTER to OHMS to the lowest value ..Now if moves a little means there is no short circuit happened but if it does the moves its maximum value then it has been shpt circuited.The armature coils might been short circuited
Jul 07, 2011 | Speed Queen Washing Machines
PIONEER DEH-P86DHR NO SOUND!!
With these units, the internal amplifier is an IC that fails sometimes. It can leave the rest of the unit working ok, bit will have no audio. There may be audio from the line level RCA's but not from the speaker outs. Smell the back of the unit to see if it smells burnt. Most of the time it will, but not always. The IC is usually something like a PAL007a or similar. If you are good at soldering, you can order the part, and change it yourself. If not, you will need to seek a technician to replace the part. You may also try an external amplifier and RCA's instead of fixing the IC.
Jun 15, 2009 | Pioneer DEH-P86DHR
T1500-1bd burnt mosfet
Fosgate's get very hot.My first amp was a fosgate and I freaked out because it got really really hot. And smelled bad. So I moved it so where it could get more air That should help you out a lot and the smell went away on its own. As for your battery dying. Basically your stressing out your battery and your alternator is having a hard time keeping the battery changed. I'm sure you see your light dim when a low bass note hits. Invest in a cap. This will help save your battery your alternator and should even sound better.
Feb 08, 2009 | Rockford Fosgate Power 1500.1BD Car Audio...
Ignition problem
Check for burnt "fuse wires" these are wires that as their name implies, they react like fuses. They are obvious to see. you will see soot type stuff and they will LOOK burnt out. Also check your starter. It could be that one of the wires in the starter got hot and burned out. Check you relays and fuses.Under the hood and inside the cab,.
Jan 15, 2009 | 2002 Pontiac Grand Am
I have a intertherm furnace that won't kick out just keeps going
Hello , I think I can help , with the power off to the unit disconnect the wiring on the thermostat and remove it make sure the wires are not touching, turn power back on and see if the unit still runs , if not thats the problem pickup a new tstat , if it still runs then you have a sticking contactor in the control panel of the unit , all of the componets in the unit feed off the contactor and its easy to find its about two inches by 3 inches. There are a set of contacts in it that will be blackend or burnt , remove, label all wires where they were going and pickup a new one at any Hvac, A/C warehouse.
Hope that helps , let me know how it turned out.
Dec 30, 2008 | Intertherm P3RA-048K Air Conditioner
Televison & Video Logo
53 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
