3D tv Are there any VESA output adapters( to connect the emitter) to make an older DLP TV compatible with 3DTV?
  • 981 Answers
No; and your question doesn't quite make sense either.  What's really strongly missing is a citation of a particular 3D TV technology (or at least that glasses with cross-polarized lenses are required, or some other method.)
Posted on Aug 18, 2008
Looking for external speaker outlets on a Insigina 55in model 4806800 NS-550510NA
The model number is NS-55D510NA17 (in the US). The input and audio outlet ports are all on the right hand side of the back where the VESA mount is. (This part of the TV is a bit deeper than the rest of the TV; so look sideways at the back.) See page 9 of the manual (page 13 of the PDF, listed below). At the bottom of this I/O port area, there is a digital optical audio output. There is a 3.5 mm headphone jack (analog audio out) just below the antenna input near the top of the I/O port area. Depending on the type of speakers/amplifier that you are connecting to the TV, you may need an adapter/converter. For most analog audio devices, you may need an RCA audio (M/M) to 3.5 mm cable or adapter.
The product page is https://www.insigniaproducts.com/pdp/NS-55D510NA17/4806800 . Click on the Support & Downloads tab. The direct link to the User Manual (in English) is currently: https://files.bbystatic.com/tO8X36kluhi9vR%2FyhhN3kg%3D%3D/NS-48-55D510NA17_55D510MX17_16-1085_WEB_V4%2BENG_Final_lr.pdf .
I hope this helps.
Nov 14, 2017 | Audio Players & Recorders
How do i turn off the speakers on my toshiba 55tl515
There is no way to disable the speakers on the 3DTV 55TL515U, I would just turn the volume all the way down on the TV. If you are using the opticla output this should not be affected. If not than you have no worries anyways. Mute or Volume Down.
Apr 09, 2014 | Toshiba 55tl515 55 1080p Led 3d Tv...
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
How I can connect my Samsung Home Theatre System ( 7-1 channels AV receiver) using the HDMI V 1.4 3D cables to connect them to to my LG 55 LX 9500 3D HDTV LED TV . The equipments are :( LG Blu Ray...
ideally you would simply add an hdmi source from each device to the surround receiver and send the output to the tv but im thinking your amp may be short on inputs from all devices and if indeed it was this simple you wouldnt be here seeking this info also note you may be able to use the output on the set to gain another signal tranfer but note there can be compatability issues on some sets whether they will decode hdmi in and rca out or optical out like i said some sets ok :) i wish you luck and wishin i had this all in front of me so i could be a greater help any q's drop me a comment here ok :)
Feb 26, 2011 | LG Televison & Video
I have the 73738 DLP 3D ready TV. Purchased the Mitsubishi starter kit with glasses and emitter and the TV is saying it's not compatible. Just get an ugly pink haze or shadow effect over the picture. The...
There is new software upgrade for the TV that should fix the problem you will need a usb memory stick and go to http://www.mitsubishi-tv.com/3dupgrade or you can call mitsibichi consumer relations and buy a usb stick with the upgrade on it.The new software version is 012.06 or higher
Jan 21, 2011 | Mitsubishi WD73738 73 in 3D HDTVReady LCD...
3D doesn"t work
You will need a 3D-capable or 3D Ready tv. The difference is the 3D-capable tv will require you to buy a piece of equipment called an emitter to connect to it. The 3D Ready tv already has an emitter. You will also need a 3D bluray player or Playstation 3, 3D glasses, and hdmi version 1.4 cables. You will need 3D glasses and 3D bluray Dvds. If you want to watch something besides bluray dvds you would have to subscribe to direct tv as they are now offering some 3D broadcasting.
Jun 15, 2010 | Philips DVD724AT DVD Player
I have a Samsung LN32A450 and a Peerless SGLs01 mount. I need to put on the universal bracket onto the back of my TV but the back of my TV is not "flat", is more like a small S-curve so the lower part is...
That TV is new enough to have a VESA standard connection on the back, try attaching the mount directly to the 4 screw holes on the back, tv's don't normally need an adapter if the back is fitted with VESA. if not you can find low cost adapter plates on www.etvmount.com for the most part any vesa adapter than matches your size will function fine.
good luck-
Will
www.compressionconnector.com
Feb 19, 2009 | Akai LCT2721AD 27 in. LCD Television
Computers & Internet Logo
401 people viewed this question
David Payne
David Payne
