Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
My MTS2000- NTN1168A Battery charger's red and green lights are constantly flashing. I am trying to resolve the issue, but without success. Please HELP?
2 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: When I try to charge
1) Hand oil can cause a film on your battery contacts. Clean your battery contacts on both the radio and the charger with a pencil eraser and try seating the radio/battery on the charger again. Be certain the radio is turned off.
2) It is possible your battery is too low to charge. A form of jump starting would be to let the battery set on the charger for more than 3 hours to see if the light problem clears.
3) It is possible you have a bad or shorted battery. Try another known good battery on the charger to see if the charger reacts correctly with a solid red light at the beginning of a normal charge cycle.
Best regards.
Posted on May 27, 2011
Why does the light fladh green and then stay green even though there is no battery in it!?
If you can remove the battery, remove it.. Wait about 30 seconds+ Then place the battery back in and try charging it again. This is a solution that fixes quite a high percentage of battery related issues.
EVEN works with laptops. Hope this helps. So many other issues could be wrong with your phone or source of power.. Good luck.
May 09, 2014 | Computers & Internet
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Mar 17, 2012 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
My charger blinks red and green but I've literally only used my chainsaw 4 times. It's less than a year old. It won't charge the battery. What could be the issue? Or can I take it back to home Depot and use the warranty? Any help will be welcome.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
When I try to charge my batteries the red and green lights of my NTN1168A desktop charger flashes. I use the MTS2000 hand radio.
Best regards.
May 26, 2011 | Motorola HT1000, MTS2000, MTX8000/9000...
Red light constantly flashing. I can't make it stop to pair it..
How to perform a system reset
Start with the headset off (no light). Press and hold the on/off button and without letting go plug in the AC charger (you will see steady light on the headset). Let go of the on/off button as soon as you see the steady light. Unplug the AC charger from the headset. Test the headset to see if the reset was successful.
If this does not resolve your issue you may have to replace the headset through Plantronics Service Center.
Good luck from Headsets Direct!
Dec 12, 2010 | Plantronics Backbeat 903 Bluetooth...
Will the light turn green on the ht1000 charger when the battery is charged? how long does it take?
It depends on the type of charger, a rapid-charger would charge a battery in one hour or less and the green light would come on when battery fully charged. A slow charger will take up to 16 hours to charge a battery and has red light only.
Nov 28, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I have constant red and green flashing lights on my charger
The red and green flashing lights on a Ryobi charger is a dead battery, or defective, won't charge. I hope that is what you are talking about.
Nov 15, 2010 | Grinders
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
129 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
