Question about LG WD-3245 Front Load Washer / Dryer
My washer lg wd-3245rhd will not drain, not even from the manual hose close to pump filter.
  • 489 Answers
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
Posted on Jun 15, 2011
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
When i plug washer in,cl displays on screen and machine will not turn on.
There is no "cl" error code for the LG WD-3245RHD. Your display unit may be bad, because there is a "cE" error code, which indicates an overload in the motor, and the suggestions in the manual are to close the tap, unplug the machine and call a service technician. So far, I have been unable to find anyone that will adequately service any LG appliance. It seems they think of their products as disposable, not repairable.
Oct 29, 2010 | LG WD-3245 Front Load Washer / Dryer
OE Error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!!!
Jul 13, 2010 | LG WD-14124RD Front Load Washer / Dryer
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
LG Washer/Dryer won't drain
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
LG WD-3245 Front Load Washer / Dryer Logo
255 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
