Question about Vivitar ViviCam 6150s Digital Camera
Sd card when i insert the sd card and try to view photo it just says no image ...works fine without card , i have tryed formatting and still no joy (camera is brand new) thanks
    Novelist:
  • 103 Answers
Please tell me the make and model of camera. Some have internal memory and unless that is switched off through their menu option, you'll never get images written to the SD card.
Posted on Sep 27, 2008
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Hi: I have a SDHC 16GB card using by the Lumix FZ35 camera. It worked fine on the first 4 days of my trip and all of a sudden, it is now displayed with ''INSERT SD CARD AGAIN'' message whether I try to...
At any time did you insert the card into your computer to "have a look" and then remove the card without using the "safely remove hardware" function? You may now need to download the pics from your card to the computer, then format the card in the camera to get it to work properly again.
Apr 14, 2010 | Cameras
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Photo transfer
change the pic format options in the camera to read *.jpeg intead of *.raw
if they are in jpeg maybe the computer dosn't understand the way the camera formated the sd card mine dose the same thing when i try to tranfer images from my aiptek dzo-v50 without the camra i just get card read error
Oct 21, 2008 | Cameras
Computer can't see images but they look fine on the camera.
May be problem in card reader...
But i'm think than you should try to use another cable (who connect card reader with computer).
May 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
SD card
you can try some data recovery software. You can see
recover files from sd card
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use sd card recovery software to scan again the memory card and recover your files.
Jan 24, 2008 | JVC Everio GZ-MG130 Camcorder
Vivitar ViviCam 6150s Digital Camera Logo
75 people viewed this question
Top Vivitar Cameras Experts
Tony
Ron Dufek
Ron Dufek
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
