Question about Canon Rebel XT / EOS 350D Digital Camera
My Canon Rebel EOS autofocus is not working. It will not move at all nor will it take a picture. If I place it on manual the flash will pop up and take a picture but it is not in focus. The AF is not working at all. I see a flashing green dot inside the viewfinder with a 9 to the left of the dot. Help!
  • Canon Master
  • 17,970 Answers
It could well be the lens, take it off and clean the contacts on the lens and body. Other suggest about this problem... first in manual or auto focus mode does the green in focus confirmation light come on in the lower right corner of the viewfinder? Are you shooting in One Shot-AF, have you selected an Auto Focus Point are your pictures in focus?
If that green confirmation light comes on then the picture will be in focus. a few things that will mess up focus are little or no contrast. No contrast like huge expanses of water, sky, glass or infinity will render a auto focus system near useless. Something that is good is that you haven't said anything about error codes which is good. These questions my sound lame but ask yourself this when was the last time I cleaned the lens (Front Element) use a lens cloth for this and huff on it if a little moisture is needed. Do you change lenses often and when was the last time you checked your sensor for dirt?
If you have had the lens off you should check the rear lens element for finger prints or oil. A dirty rear lens element will cause everything to look as if it's shot in a dream world. Check your camera sensor buy taking a (manual) focus shot of a piece of clear blue sky download it to the computer increase the size to 100% and check out the blue for dirt. A camera that's two years old and used "normally" may need the sensor cleaned. But go back to this infocus light if it's coming on and the pictures are out of focus then you have another problem as in dirt.
Keep us updated.
Posted on May 26, 2011
Canon T3 flash flutters and does not take pictures help!
The 'fluttering' is a pre flash used to help the camera focus in low light. The internal flash isn't a powerful flash and is usually only good enough for subjects up to about 2m away in reasonable light also to light a subject that is back lit. Try putting the camera in manual mode (M) 1/60sec on f5.6 flash popped up review it and make adjustments accordingly i.e. open up or shut down the aperture as the flash usually syncs at 1/60
Aug 13, 2017 | Canon EOS 1100D / Rebel T3 Digital Camera
In my Canon 4ood Even after i pressed halfway and the autofocus point has blinked to indicate focusing is done but focusing is not happening and the shutter won't fire.With manual focus i'm able to take...
If it is a dark scene and the camera cannot detected edges well the autofocus will either move around a lot or simply will not focus and thus wont expose. You will just have to manually focus or use the flash
Mar 01, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon EOS rebel suddenly won't take pictures in dim light. The flash pops up and blinks and blinks trying to register the image but won't ever autofocus and take the picture. The light has to be very...
To autofocus the sensor needs a fair amount of contrast (light and dark eges) to operate. If you're trying to take a photo in a dim room of a dark colored subject for instance the focus won't lock and the camera won't take the picture. Try switching your lens to manual focus and shoot that way.
Jan 07, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
I have a Canon Digital EOS Rebel XT and the built-in flash no longer pops up when needed. This started happening after using a Canon speedlite, but then removing it. I've tried resetting everything, and...
In addition to resetting all the camera settings you should also choose the "clear all custom functions" option that is also available from the same menu. Once that's done. Put the camera in Full Auto mode and see if the issue is resolved.
Sai.
Oct 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS - no data on LCD and viewfinder says busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Nov 04, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Will a quantaray 28-105 1:3.8-5.4 Zoom lens Autofocus from a 35mm rebel ti fit on Canon EOS Digital Rebel 6.3 MP 300D?
The 35mm Rebel Ti and the Rebel 300D use the same lens mounting protocol. All Canon cameras designated 'EOS' use the autofocus EF lenses. If your Quantaray lens worked on the Rebel Ti, it will fit and should work on the Rebel 300D.
Mar 19, 2009 | Canon Digital Rebel / EOS-300D Body only...
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash problem
Move the mode dial to the no flash setting (full clockwise position)which is basically full auto with no flash (page 47 of manual)
Jul 02, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
