Question about Panasonic PT-LB10SVU Multimedia Projector
My PT-LB10SVU projector quit working and I thought it was the bulb so I installed a new one but it still does not work (no light), what do you think it is or where can I send for repairs, I live in Surrey, BC...Roy
  • 2,632 Answers
Welcome to Fixya. After changing the bulb and still won't work it can be that the problem is with the either the parts of the board or the mainboard itself. You can send it to repair to check which part needs to be replaced.
Panasonic - 604-533-5050
317-19292 60 Ave, Surrey, BC V3S 3M2
Panasonic.ca
3033 King George Blvd, Surrey - (604) 531-8331
Thanks for using Fixya.
Posted on May 26, 2011
Replacement bulb not working on HP vp6121
The ballast board controls the bulb. It is the board with the wires going to the bulb socket. Replace that and you'll have a working projector.
Jul 23, 2016 | HP VP6121 DLP Projector- XGA 2000 Lumens...
How to clear the counter hours lamp?
use the menu,
select main menu, option 2, lamp runtime, then press and hold the enter button for 3 seconds. after it resets, turn power off.
Jun 17, 2011 | Panasonic PT-LB10SVU Multimedia Projector
The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
I don't have a remote and I changed some setting and now the buttons on the projector unit do not work how do I reset the projector settings
Press and hold the MENU button for 2 seconds with pressing the ENTER button.
now you are enter the menu and chang the control panel setting to VALID.
(buttons are located back side of the projector)
Dec 06, 2010 | Panasonic PT-LB10SVU Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Panasonic PT-AE900U Projector Lamp stops working (intermittent)
    Could be a heat sensor, fan bearing issue..have you listened to the fan speed etc, But I think more along the lines of the lamp needs replacing..each time you resit it is thinking ah a new lamp and then realises hey someone is fooling me and shuts down...this scenario is doing you a favour as typically if it blew and shattered the glass it will inevitablly scratch the mirror and lcd block... and if it does that you might as well toss it in the rubbish or sell on ebay for $50 ..
    Regards Kevin Andreassend, ICE AV Technology Ltd www.iceav.co.nz iceavtech@gmail.com
    Apr 03, 2009 | Panasonic PT-LB10VU Multimedia Projector
    Panasonic PT-LB10SVU green light flashing,then orange,lamp light
    i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
    Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
    since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
    if the brightness is adequate, then it is a ballast problem & not lamp problem!
    buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
    Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
    My picture brightness is uneven - there is a persistant bright field on my screen.
    I have the exact same problem with my AE700. It a started about the same time, around 2500 hours for me. I lived with it untill I could afford a new bulb which arrived yesterday. The old bulb was still working at a 3603 hours when I installed the new one. But the new bulb didn't fix the problem for me either. I may try to take it apart this weekend and give it a good cleaning. Andy
    Jan 07, 2007 | Panasonic PT-AE700U Multimedia Projector
    Bad Lamp lights even with new bulb.
    confirm that it is not made in china-because some chinese lamps is not good in life time.
    Dec 02, 2006 | Dell 2300MP Multimedia Projector
    Panasonic PT-LB10SVU Multimedia Projector Logo
    221 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
