Question about Dyson DC25 All Floors Bagless Upright Vacuum
The brush bar is not turning. I have not seen or heard a belt but it's not turning.
  • Official Brand Answer
  • 2,572 Answers
Sorry to hear you're having a problem with your DC25. You should be able to resolve the issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1566&product=DC25-ALLFLOORS
If you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 09, 2011
Dyson DC17 Loud Noise when using brush bar. I have replaced the brush bar and belt with new ones. No load screaming until using brush bar. Pretty sure its the brush bar motor bearings. Can these be...
Hi Ed,
I'm sorry to hear you're having difficulty with your DC17. It's worth checking that the new brush bar and belt are fitted correctly, and rotate freely. The video attached may help in making sure it's correctly aligned.
It's worth checking that no threads, hair or debris are caught within the machine. The brush bar motor itself isn't designed to be serviced, and we would advise against attempting this in case further damage is caused. I'd encourage you to email our experts directly with our contact details - you can reach them at askdysonUS@dyson.com. Someone will be in touch as soon as possible to take you through some diagnostic checks to confirm what's causing the noise.
If you'd prefer to call our customer Helpline, you can reach us on 1-866-693-9766.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Sep 26, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Belt no longer turns the brush
JKGonzo:
You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
May 25, 2013 | Rainbow Vacuums
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
Jul 21, 2012 | Dyson DC25 All Floors Bagless Upright...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Frozen Beater Bar
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
Jun 19, 2017 | Bissell 6594 PowerForce Bagless Upright...
My dyson dc 07 brush will not rotate. I have cleaned all hair and debris from around the brush and no change. I can not even figure out how to look and see if the belt is still attached. Suggestions?
DC07s are not easy to check the belt on, in fact depending on which exact model you have there are probably two belts.
One connects the output of the motor to the clutch mechanism (one end of which has the control knob that lets you turn off the brush bar completely), and the other connects the clutch to the brush bar.
The clutch to brush bar belt is easy to check as the belt can be seen running over the brush bar if you remove the sole plate. The other belt is "hidden" under a plastic cover secured by three Torx screws. These need a special Torx driver to remove so unless you have a well tooled-up friend, this may mean a call to Dyson for help..
The site www.dysonmedic.com is excellent, but may not cover your exact DC07 in full.
Good luck !
Aug 28, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Dyson DC25 All Floors Bagless Upright Vacuum Logo
658 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
