Question about Intel Foxconn Motherboard
Foxconn Pheonix Bios d686 (quite old) motherboard when plugged in the cpu fan moves but when i press the power switch nothing happens i have even unconnected everything and it still doesnt work. What do I do?
  • jack_bedlow May 26, 2011
    The both the fans on the motherboard and powersupply are working and I have had the pc running before which is why I dont understand why it isnt working now?? But thanks for the help
  • Intel Master
  • 27,725 Answers
Test your power supply unit if the PSU units fans not working its faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error computer error a computer needs its connections continue its cycle and have an end to function
hope this helps
Posted on May 26, 2011
  • Brian Sullivan
    Brian Sullivan May 26, 2011
    even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
    a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
I was running a gigabyte MB ,.then powr supply failed baddly,.. I purchased a used foxconn MB and diffnt PSupply,..I put the CPU on foxconn MB and mounted in old case w/ what I think is good PSupply,.. but...
did you connect the cpu fan and fan 1 power feeds in on motherboard ?
from
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket478/661FX4MR-ES/manual/English/661FX&648FX4MR-Eng-easy%20guide-09-04-04.zip
Sep 05, 2017 | Foxconn 661FX4MR-ES Motherboard
Bios not starting
Gitu, remove tha fan, the cpu and the RAM. RE fix them in their respective places. Switch the machine on It shud work. Check the battery on the motherboard. May be it is dead. How old in your machine? Replace the button cell on the motherboard.
Aug 05, 2009 | Intel SuperMicro SUPER Motherboard - 810...
No graphics on monitor whatsoever, screen completley blank
i think there is a problem with your system's hardware.. check whether your MOBO or your processor.. computers that doesn't startup and has no beep has defective or burned CPU or motherboard
Apr 18, 2009 | Foxconn 661FXME Motherboard
The pc did not turn on
It looks like your HDD or ROM has problem. Mostly your Hard Disk must have failed.
Apr 17, 2009 | Computers & Internet
Foxconn A74MX motherboard will not pick up my PCIe Graphics card
disconnect everything except the power supply, the power on switch, one stick of memory and the graphic card (if you don't have onboard adapter), turn it on and see what happens.
Mar 28, 2009 | Foxconn Computers & Internet
Foxconn 915 motherboard - no POST sound
you need a new motherboard this one will not support that cpu get one rated for that cpu and by the way this motherboard only is rated at Intel Pentium 4
Dec 27, 2008 | Foxconn MB 915A03-G-8KS 915G RET...
Your motherboard does not support the Intel Core 2 Duo cpus. That is why it will not post.
Dec 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
Cant access advanced bios settings
to access the Bios Configuration Setup, On Any PC.
Depending On The Bios Manufacturer i.e Pheonix-AMI et,c.
You press F2 Or Delete Or Esc At The Initial System Boot-Up.
Power On. Press One of the designated Buttons immediately, after starting the computer.this should access the Computers Advanced Bios Settings.
** Please note:- Altering any settings in the bios, can cause undesireable effects to your computer**
Even failure To Start, Or Boot-Up.
From my own personnal experience, it is better to underclock a cpu rather than overclock it.
If a CPU Is designed To Run At a certain speed, running it above it,s designated speed cycle, can damage either the CPU Itself, the Memory Or Motherboard.
Probably wiser, to upgrade The CPU rather Than Overclock It.
Mike @ Compurepair.
May 11, 2008 | Intel Desktop Board D845BG Motherboard
Intel Foxconn Motherboard Logo
248 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
