Question about Car Audio & Video
I have a 77 Olds Toronado and bought a new radio for it which is supposed to be an exact replacement. I need to know how to get the old one out. Where can I get instructions?
  • rfisher95 Jun 09, 2011
    This is close and I'm pretty sure the wood grained plastic panel surrounding the radio area is removable but there are no screws or other fasteners visible to loosen. I'm thinking that removing the radio knobs and the nut underneath them might be what is holding the plastic panel in place. I'm going to try removing those nuts and see it the panel comes or can be pried loose.
    Agree?
    Thanks,
    Rick
    This was helpful and worth the price. Thanks!
  • 17,970 Answers
Toronado was a two-door coupe produced by the Oldsmobile division of General Motors from 1966 to 1992, more similar to the Cadillac Eldorado than the Buick Riviera,
This could help like a reference guide: InstallDocs/GM/PDF/460013.PDF
Hope helps.
Posted on Jun 09, 2011
  • ZJ Limited
    ZJ Limited Jun 09, 2011
    Agree with you. I could bet that this is the right way to resolve this issue. Unfortunately the data on your vehicle is fairly limited, the locks are often hidden under the moldings and in other cases, moldings just fixing teeth that are part of the frame and entering with a few hold.
  • ZJ Limited
    Your welcome; thank you for using Fixya.
Is the ac compressor controlled by the computer on a 87 olds toronado?
An '87 Olds Toronado has three computers: the ECM (engine control module), the BCM (body control module), and the IPC ( instrument panel cluster). The A/C compressor is controlled by the body control module.
May 02, 2014 | 1991 Oldsmobile Toronado
91 olds toronado won't start battery has full charge.key may need programmed?
Only reprogram if you know it needs programming otherwise you are wasting your money. Take the key to a main dealer and ask them if the programming is still working as you are having trouble starting your car.
They should be able to tell you if it needs programming or not.
Apr 12, 2014 | 1991 Oldsmobile Toronado
92 Olds Toronado - where is the ALDL connector located? trying to program new key fobs.
Under the dash, to the left of the steering column. It may have a plastic cover.
Aug 31, 2011 | 1991 Oldsmobile Toronado
1990 olds toronado, replaced coil pack, 2and 5 cylinder still no spark
should pull ignition control module under the coils n take to any parts store to test it
Sep 29, 2010 | 1990 Oldsmobile Toronado
Hello,I just bought a 1987 Olds Toronado
is yours carb,if not 23- manifold air temperature (mat) sensor or circuit (1990 and earlier models) 23- intake air temperature (iat) sensor circuit (fuel-injected models) if its carb,,,,,23- mixture control (m/c) solenoid or circuit (carbureted models)
Nov 17, 2009 | 1987 Oldsmobile Toronado
I need a repair manual or a vacuum diagram for a 67 olds toronado
ebay has some manuals for around 25 dollars or you can try
http://www.toronado.org/FAQ/GenI/oldsfaq1.htm
http://www.toronado.org/FAQ/GenI/66vactub.htm
or olds442.com
Mar 16, 2009 | 1992 Oldsmobile Toronado
1992 Olds Toronado dash lights and heater fan out
The Speedometers go bad, the digital ones and need rebuilt or replaced
Jan 07, 2009 | 1995 Pontiac Bonneville
Rear shocks have inflated fully and will not go back down
it would be cheaper to replace the shocks with the same as you have on the car now. otherwise you have to have other things done to the car to make new different shocks workfor the car
Dec 07, 2008 | 1992 Oldsmobile Toronado
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
