Hardisk pls help me on how to repair my hardisk..cannot be detected....
    Champion:
  • 214 Answers
Hi, check the connections first, boot the system and enter BIOS, check whether its detecetd or not. if not check the jumber settings-set it master.
if this also does'nt work let me know
thanks
Posted on Aug 16, 2008
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
By startup fails to see IDE 0 and IDE 2 , says no channel 0 and channel 1. Is it possible that the cmos battery is empty?
Once your powered on the CMOS battery is no longer an issue. If it isn't reading the IDE or SATA channels it could be because they are not set in the BIOS. Check your BIOS setting and double check your cable connections. You also need to make sure, for IDE devices, that one of the drives is set to Master and the other to Slave otherwise they confuse the board and cancel each other out.
Jan 03, 2011 | Asrock P4VM8 Motherboard
Boot fail
Pls refix your hardisk cables.After refixing it hardisk does not detect then hardisk has been faulty so it need to be replaced.
Sep 15, 2010 | Computers & Internet
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
There is a blue screen then it shuts down
i have this problem before, actually there are many causing blue screen. it might be the memory, hardisk, and the corruption of windows files etc. for you check first your hardisk if detected in your bios setup. if hardisk detected run safemode. then repair your windows.
Jun 25, 2009 | Toshiba Satellite A10-S100 Notebook
I cant re format the acer4620series
hi!!!
maybe the hardisk has defect or damaged
try to borrow some hardisk from your friends
or buy new one and then reformat!!!!
Oct 30, 2008 | Acer Aspire 3050-1733 Notebook
Hardisk not detected
Is this the only HD in your system? If so, make sure the jumper on the drive is set to Master. Also make sure you use the Primary IDE controller. Make sure the IDE controller is enabled in the BIOS also.
Oct 16, 2008 | EliteGroup L7VMM2 Motherboard
Pls help
configure wireless network
Press Fn (Function key) at the lower left hand corner and F2 at the same time.
select Internet tab>>click on wireless networks.
select the wireless network that you have, and click connect.
this is where you need to know what kind of encryption you have on the wirelss network.
select encryption type. (WEP, WPA or other).
enter passkey for the network, and Press OK
Sep 12, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
David Payne
David Payne
