Question about Microsoft Windows XP Professional for PC
Problem after i right click the c or d icon of the hard disk, it states that the c: application cannot run in win32 mode
  • kedari68 Aug 16, 2008
    please help me if u can
  • 407 Answers
Some virus effect your pc you can load any update version anti virus
on your pc..............
Posted on Aug 18, 2008
Unable to install 3.1 in windows7
install the app as admin. then go to the installed apps propereties and tell it to run as a xp app in compatibility mode
How to Use Windows Application Compatibility Mode Published: October 25, 2001
This article describes how to use Windows Application Compatibility mode. This mode provides an environment for running programs that closely reflects the behavior of earlier Windows operating systems.
Using The Windows Application Compatibility Mode
When you use Windows Application Compatibility mode, many of the most common issues that prohibit earlier versions of programs from working correctly are resolved. If you run a program and it does not function as expected, it is recommended that you run the program in one of the compatibility environments.
To run programs in Windows Application Compatibility mode in Windows XP
  1. Right-click the icon of the program that you want to fix.
  2. Click Properties.
  3. Click Compatibility tab.
  4. Click Run this program in compatibility mode and select one of the following options:
    • Windows 95
    • Windows 98 / Windows Me
    • Windows NT 4
  5. Under Display settings, check the mode that you think is necessary for the program to work correctly:
    • Run in 256 colors.
    • Run in 640 X 480 screen resolution.
    • Disable visual themes.
  6. Click Apply.
  7. Click Ok.
  8. Double-click the program icon.
    Note The Compatibility tab is only available for programs installed on your hard drive. Although you can run the Program Compatibility Wizard on programs or setup files on a CD-ROM or floppy disk, your changes will not remain in effect after you close the program. For more information about an option on the Compatibility tab, right-click the option and then click What's This.
Oct 30, 2010 | Primavera Project Planner P3 (PRIMAVERAP3)...
C: application cannot run in win32 mode ...huh???
may be your system restore disk omnly supports system 64 .
Nov 14, 2008 | Microsoft Windows XP Professional for PC
Error: "The application cannot be run in win32 mode"
click on start>>all programs>>accessories>>communications>>network setup wizard. follow the online instruction to describe yr network to the end u can access yr hard drive
May 22, 2008 | Computers & Internet
D:\ application can not run in Win32 mode
hi
go to start-run c:
if u can open it your sys is malware infected if u hace winxp sp2 pro and fat32 or ntfs partition.
scan your sys with avast ,qiuck heal and symantec update
Mar 26, 2008 | PC Chips (M925G) Motherboard
Open my system, click mycomputer and then opening only c drive, but D,E,F drives are not opening, if telling application cannot be run in win32 mode ( how can i solve the problems.)
Jan 07, 2008 | Microsoft Windows XP Professional for PC
Open drive
Go to Start/Run and type :
reg.exe add "HKCR\Drive\shell" /ve /d "none" /f
then type:
regsvr32 shell32.dll
Dec 18, 2007 | Microsoft Windows XP Professional for PC
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Dec 15, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
