My toner cartridge has loose toner on it when I pull it out, is it just the cartridge or is there another issue
    Sergeant:
  • 217 Answers
That's normal the powder is messy and leaks.
Posted on May 26, 2011
Manual for mfc-7360n how too change toner cartridge
To replace toner cartridge, follow these steps:
1. Open front door on printer
2. Pull the toner/drum assembly towards you. The toner cartridge sits inside the drum.
3. Press blue (or sometimes gray/green) latch on the left oof the drum assembly and pull the toner cartridge up and out.
4. remove packaging material from new toner cartridge, including tape which you pull by the latch on the side.
5. Insert cartridge into drum and insert drum with toner inside the printer.. See video below with better instructions. Start from minute 4:00.
Jun 07, 2017 | toner Office Equipment & Supplies
Printer prints blank pages
This is almost certainly an issue with the toner cartridge. I would recommend running off 30 or so prints and contacting whoever the cartridge was purchased from if the toner doesn't pull through.
Nov 18, 2012 | Brother HL 2140 Laser Printer
How to remove the cartridge on Brother HP1440 printer
Hi seevram,
Follow the procedure below to remove and replace toner cartridges for your Brother HP1440 printer:
1. First, open the Front Cover of the printer.
2. Remove the Toner Cartridge(s) that has run out of toner. Pull the Toner Cartridge out slightly with one hand, then hold the Toner Cartridge with both hands and pull it out of the printer.
3.
After rocking each new Toner Cartridge 3 to 4 times from side to side, remove the tape labeled 'REMOVE' and the orange protective cover from the new Toner Cartridge.
4. Then,
insert the new Toner Cartridge(s) by positioning it in the correct guide(s). Slide it gently into the printer.
Reminder:
  • Do not try to lock or push it in; it should rest loosely in the guide rails.
  • Each color cartridge is individually keyed to prevent improper installation. Match each cartridge color label to the corresponding label on the printer.
5. Finally, close the Front Cover.
Also, I have included here a link where you can download a service manual for your Brother HP1440. Kindly click here.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother HL 1440 Laser Printer
HOW TO REMOVE TONER CARTRIDGE TO REPLACE WITH NEW ONE
1. Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
2. Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
3. Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
4. Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
5. Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
6. Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
7. Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 09, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
Instructions for refill tonner
Changing the print cartridge
1. Open the print cartridge door, and remove the old print cartridge. See the recycling
information inside the print cartridge box.
CAUTION To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
2. Remove the new print cartridge from the packaging.
3. Bend the tab on the left side of the cartridge to break it loose.
4. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling.
5. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the
cartridge.
6. Insert the print cartridge in the printer, making sure that the print cartridge is in position.
Close the print cartridge door.
CAUTION If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
Hot water sets toner into the fabric.
Oct 31, 2009 | HP LaserJet 1160 Printer
We have been sent a toner cartridge for our ir3300 but despite directions on the side of the box it does not appear to fit
Canon toner type GPR-6, correct? Open the front cover. Rotate lever to release toner/developer unit. Pull the unit straight out until it stops. Insert new cartridge to line up with top of toner/developer unit at a slight angle (lower at back) Once the cartridge stops at the rear (I would hold the toner/developer unit with one hand while inserting the cartridge) then lower the front end of toner cartridge down on top of the unit.....press down until toner cart. clicks into place. You will know because a tab pops out the front with clear plastic attatched. Pull the tab to release toner and release top of toner/dev. unit. Keep pulling until it stops. Wait about 7 seconds, now tap on toner cartridge to release all loose toner (don't forget to shake toner before opening) After about 15 seconds, toner should be fully loaded. Now push top cover of toner/developer unit back in until it latches, you will know because the empty cartridge releases from the unit. Now remove empty cartridge, reinsert unit, turn latch handle and close front cover.
Oct 07, 2009 | Canon Office Equipment & Supplies
Removing toner cartridge
When the toners go in, they are locked down using the colored part of the cartridge. This holds them in place for printing. However, sometimes even when unlocked they can be very difficult to remove.
After you are sure it is unlocked, do your best to wiggle the cartridge until it start to feel like it is coming loose, and you should be able to pull it out. Do not under any circumstances force it out, just take some time to loosten it up.
Oct 23, 2008 | Dell 3000cn Laser Printer
k24674
jasbo
jasbo
