Technics SUV4X new class A Amp - 20 odd years old but lovely sound !!
Amp gone into "safety operation" mode - flashing amber light+no output.
Amp is connected to 1pr. 8ohm KEFS + 1pr. 8ohm CELESTIONS(correct impedance selected on amp). I had it on 3 of 10 ( loud amp - 65wpc ) and the output suddenly stopped and amp went to above mode. i switched it off and noticed the transformer was hot - although well ventilated. ive taken cover off and checked the 2 fuses i could see ( both ok ) + can see no toasted components.Do you think ive cooked the transformer or possibly the output IC?. As the unit will power up i dont think the Transf. is the problem - hopefully it could be other components that are standard service items - cheaper ones??!. Thank you if you can help me. A fellow Biker !!!!!!.
  • Anonymous Aug 26, 2008
    Me too. Exactly the same. I was given the amp after my old one died (also a vintage hand-me-down!).
    The amp worked perfectly for about 9 months and then all of a sudden the 'Safety operation' light came on and now it just blinks repeatedly and no sound can be heard.
  • 1,512 Answers
Hi guys
Quick check... If the amp still stays in safety mode with the vol turned down and the speakers disconnected, it will have failed in some way. Since you have the safety operation light ON, you can expect that the power transformer is OK. I would expect that you have a DC offset condition on one channel. The most common problems you may have are
  1. dry solder joints about the power stages such as regulators, and output/driver transistors/IC's.
  2. blown output transistors/output IC with possible fusible resistor failures, and or sometimes burnt up printed circuit tracks.
  3. a voltage rail failure from a burnt fusible or power supply component.
If you are up with electronic fault finding, soldering and have the tools, have a go yourself, I could talk you through it. If not, I would suggest you contact you local HiFi specialist and find who can repair it or at least check to see what has failed for you. Good Luck. If you cannot find someone, hit me back and I will try to find someone for you. Cheers
regards
robotek
Posted on Sep 06, 2008
Posted on Jul 28, 2009
Hi, I want to know what is the best way to wire these subs. (Pair). I have heard of several ways. I have a 4 channel amp the soundstream picasso 4.760. Bridged it produces the most power. I was told...
Hello , I will be glad to help you.As far as your speakers..It depends on what impedance your subs are rated and if your Picasso amp can be bridged at 4ohm or 8ohm. If your subs are 8ohm each you can wire your subs in parallel and wire them to picasso amp in bridged mode. If your subs are 4ohm each.Then wire the subs in series then wire them to amp in bridged mode..caution do not wire subs in parallel if they are 4ohm .This would bring impedance to about 2 ohms and would be harsh for amp to handle...Goodluck
Sep 22, 2011 | Planet Audio BB212D Car Speaker
I have a guitar head stack with 2 8Ohm outputs and a 2x12 orange ppc212 slant with 16Ohm impendance. How to link by 8Ohm the two parts?
As long as the impedance of the speakers do NOT go below the rating of the amp you can connect them without worry Your amp would drive two 8 ohm speakers. Using the 16 ohm speaker it will only draw half the current and only accept half the power that one of the 8 ohm outputs can deliver.
Jul 10, 2011 | Orange Amps Orange Amplifiers PPC Series...
What if went in safety mode, safety mode is froze in screen. Won't do anything
"Safety" mode - literally? I don't see that anywhere in the manual.
Page 13
Speaker Connection Precautions
(North American and Taiwan models) You can connect speakers with an impedance of between 6 and 16 ohms. If you use speakers with a lower impedance, and use the amplifier at high volume levels for a long period of time, the built-in amp protection circuit may be activated.
Page 66
The STANDBY indicator flashes red
The protection circuit has been activated. Remove the power cord from the wall outlet immediately.
Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and set the volume to maximum. If the AV receiver stays on, set the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your Onkyo dealer.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 04, 2011 | Onkyo TX-SR608 Receiver
I have a punch 1000 amp and 1 l7 15 and i need to find out how i can get it wired and adjusted to 2 ohms please
I am not familiar with "I7 15" but will assume it is a speaker. Please correct me if I am wrong. As for the amp setup:
The amp output impedance is not adjustable. The amp is rated at 1 ohm which means you can connect any amount of speakers onto the output as long as the sum total of the load you connect to the amp is not less than 1 ohm.
Speaker impedance is also not adjustable but the total load connected to an amp can be altered by altering the way the speakers are connected to the amp.
The formula for calculating impedance looks very complicated but is quite simple.
First you have to understand the difference between series and parallel connections.
See diagram.
Series: Connecting 2 or more speakers by using the negative on one speaker connected to the positive on the next speaker.
Parallel ( // ) : Connecting the positive of a speaker to the positive of the next and the negative of the speaker to the negative of the next.
Connecting speakers in series is handy when you have two 500 watt speakers for instance and want to run them off an 1000 watt amp. Connecting them in series will assure that you dont over power the speaker and damage it. When connecting speakers in series the total of the impedance of the speakers is the impedance of each individual speaker added together. In our example the total impedance will be 2+2+4=8ohm
The parallel connection impedance calculation is a bit more complex.
1/Rtotal = 1/R1 + 1/R2 + 1/R2
1/Rtotal = 1/2 + 1/2 + 1/4
Rtotal = 0.8 ohm
If you have Microsoft Excel installed in your computer you can enter the following formulae as shown into the spreadsheet. After entering the formulae you must enter the values of the speakers into fields A2, B2 and C2 and it will calculate the total impedance for you.
Using less speakers just remove C2 from the formula.
For your specific amp make sure the load you connect is not less than 1 ohm. It is safe to connect more than that but using less will result in the amp protection circuitry to be activated.
If you use one speaker only then there is no adjustment to be made.
Your particular amp can also connect to an additional amp( and speaker) by using the "PASS-THRU" connectors. This saves you from using an additional set of signal wires from the head unit.
I hope that you now have a better understanding of amp wiring.
If you like you can leave a comment with the specs of the speakers you want to use (wattage and impedance) and I will draw up a diagram for you to use when wiring the system.
Nov 12, 2010 | Car Audio & Video
After playing for a while my Sony Surround Amp cuts off and shows a PROTECT Reading in the window.
Sounds like the amp is protecting itself from an over-current situation.
This happens when the machine has to try too hard to get sound out to the speakers.
There are several possible reasons.
You may be using the wrong impedance speakers for the amp.
-some amps only work with 8ohm speakers
-some only work with 4ohm speakers
If you have a short circuit in the speakers or in the speaker wiring, that could cause the amp to overwork and go into protection.
If you connect up multiple speakers to the same single output of the amp you effectively short out the amp and cause it to overwork also.
Before troubleshooting, blow out the amp, dust inside can cause lots of problems with the electrical systems. Use canned air and do it outside with fresh air.
To troubleshoot :
1. check to see that the amp and the speaker have the same impedance number, either 4 or 8ohm. This is usually printed on the back of both. If they do match go to step two.
2-unplug all the speakers, add one speaker(left one) and test it for awhile to see if it goes into a protection mode. Next move that same speaker to the right side output and run it for awhile to see if it goes into protection mode. Repeat the test with your other speaker, moving it to both outputs(L&R) to check if it works. If the amp fails with either speaker on either output, you may have a mismatch of speaker and amp or a bad amp. If you have only one speaker that causes a protection, then you have a bad speaker or it's wire. If both speakers go into protection, get different speakers and test again. if it works for all of these tests, go to step three.
3.hook up both the left and the right speakers to the amp. be sure that the wires are stripped cleanly and twisted tightly, if you have screw on outputs that is. Test for proper operation. At this point you should know if there is a single speaker causing the protection or if it is a amp malfunction.
Jan 28, 2010 | Sony Audio Players & Recorders
Looking for a schmatic for the 410 tvx 4 ohm and the 410 tvx 8ohm cabinets
Go to www.peavey.com/asstes/literature/specs/005584220_3.pdf. Apparently the 410 TVX can be used in 4ohm or ohm configurations just don't drop below 4 ohms and make sure your amp has the minimum required impedence. Hope this helps.
May 26, 2009 | Peavey Music
CORRECT CONNECTION TO AMP BEING A FOUR TERMINAL SPEAKER
Hello i_starling,
The Kicker L7's come in either 2ohm or 4ohm dual voice coil (DVC) versions.
Whatever amp they are connected to, you need to know both the impedance of your L7's and the impedance of your amp. The L7's dual voice coils can be wired to provide a total of four different loads:
2ohm coils in parallel = 1ohm load
2ohm coils in series = 4ohm load
4ohm coils in parallel = 2ohm load
4ohm coils in series = 8ohm load
Your best connection would be the one that results in a final impedance load that is supported by the amp.
Hope this helps.
May 01, 2009 | Car Audio & Video
Jl amp
The amber is the low impedance indicator and can mean that the impedance of the load is too low or there is an internal fault (shorted output transistors).
The blue LED indicates that the voltage is too low. This can be due to a bad connection or low battery voltage.You need to measure the DC voltage across the B+ and ground terminals of the amp to confirm that they're at or above 12v.
Let me know if you have any other questions.
Aug 11, 2008 | Jl Audio 1000/1 Car Audio Amplifier
500.1 amp power lights blinks on and off
Protection mode; follow this link to get a manual for the amplifier: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Below information is from the manual:
Status Indicator Lights / Protection Circuitry
There are three status indicator lights on the top of the amplifier. These are as follows:1) "Power" (Green): lights to indicate that the amplifier is turned on and operating normally.
2) "Thermal" (Red): lights to indicate that the amplifier has exceeded its safe operating temperature, putting the amplifier into a self-protection mode, which reduces the power output of the amplifier. The red light will shut off and the amplifier will return to normal, full-power operating mode if the heat sink temperature drops back to a safe level.
3) "Low ω" (Amber): lights to indicate that the impedance of the speaker load connected to the amplifier is lower than the optimum impedance load range for the amplifier. When this light is on, a protection circuit engages and reduces the power output of the amplifier. The amber indicator will also light when a short-circuit is detected in the speaker wiring (this can be a short between the positive and negative speaker wires or between either speaker wire and the vehicle chassis).
There is only one condition that will shut down an undamaged 500/1v2 completely… If battery voltage drops below 10 volts, the entire amplifier will shut itself off. The green "Power" indicator on the top of the amplifier will turn off when this occurs. The amplifier will turn back on when voltage climbs back above 10 volts. This may happen in a rapid cycle when bass-heavy program material causes a weak charging system to dip below 10 volts momentarily. If this is happening in your system, have your charging system inspected to make sure it is working properly.
For information on troubleshooting this amplifier, refer to Appendix E (page 21).
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Behringer ep2500 amplifier
Yes you can,,,,,BUT the output labelling on the AMP will tell you where you can connect the 4ohms or the 8ohms....please read these labels and connect the 4ohm speakers to the 4ohm terminals, and the 8ohms to the 8ohms terminals...
If you intend to connect the 4ohm and the 8ohm speakers in parallel then the output impedance terminals you use should be the 4ohm ones.
If there is no labelling showing any 4ohm output terminals then its best if you dont use the 4ohm speakers at all....just connect the 8ohm to the 8ohm terminals...you dont mention any crossover networks inside the speaker boxes or if you have tweeter speakers... so just stick to the basics above at present....
Cheers From YUBEUT
Oct 20, 2007 | Sunfire Cinema Grand Signature 400 seven...
3,595 people viewed this question
 Grubhead
Grubhead
