Question about Andis Improved Master Hair Trimmer
I accidentally dropped my andis Master Clipper on the floor. The ball pin in which is control by the lever broke.can u please help me? How do I replace the ball pin?
  • 62 Answers
SOURCE: loud andis master clipper
If you are keeping the blades oiled correctly and turning the screw per the instructions does not help you will need to send your clipper in for and internal adjustment. You can call Andis customer service at 1-800-558-9441 to find the service station nearest you or you can send the unit directly back to the factory.
Andis CO
1800 Renaissance Blvd
Attn: Repair
Sturtevant, WI 53177
Posted on Apr 23, 2008
  • 61 Answers
SOURCE: how to replace the cord
In order to replace cord,you'll need a sortieing gun,electrical tape, disassemble cord cut sorter-ed end and  resorter.
Posted on Jan 26, 2009
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
askmannyssha
  • 76 Answers
SOURCE: Andis Ag2 clipper blades-I dropped the 4fc blade
can you move the cutter blade (this is the smaller blade) side to side easily with your fingers if so the tension on the cutter blade has loosen. you need a special tool to reset the tension and the spec' on how much tension. send the blade to mannyssharpening.com they have fast return service and return shipping is included in the sharpening price.
Posted on Apr 18, 2010
mcdevito75
  • 1970 Answers
SOURCE: when i cut hair my andis master clipper seems to
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Posted on Jun 23, 2010
How do I remove the ball pin from the lever of the andis master clipper?
Get a finish nail and stick it in back of the ball pin, hit it with a hammer until it pops out of the other side
Mar 03, 2013 | Andis Improved Master Hair Trimmer
My adjuster on my clippers wont stay still, everytime i cut on the clipper the adjuster on the side wiggles and moves to the top..how do i fix this
Take the upper blade off of the clipper, there will be four (4) screws which secure the adjustable part of the lever to the clipper. You can tighten these screws and that will control how much resistance you get when adjusting the lever.
Feb 21, 2011 | Andis 01690 Hair Trimmer
I need to take apart my andis master clipper to see what part i need to order i need the manual take apart the clipper
Stop, Their no manual on how to take your Andis Master apart. The Andis Master has small parts that you can lose. The adjustment on this clipper are not easy to do. I
Feb 11, 2011 | Andis Master 01557 Hair Trimmer
How do you get the noise out of an Andis Master after using the adjustment screw on the outside.
you have to adjust the screw on the side of the clipper with the regular flat screwdriver, just turn clockwise until the clipper gets quiet
Jul 29, 2010 | Andis Improved Master Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
Jun 19, 2010 | Andis 01690 Hair Trimmer
My level adjuster is loose. When I go to cut it moves. How do I fix it?
Remove the stationary blade from the clipper by removing the two Phillips screws. When you lift it away you will see the plate that slides when you move the lever. Beside it are 4 smaller Phillips screws, two on either side. Tighten these very, very slightly. Repeat, very slightly until you achieve a stiffer lever action taht is comfortable to you. Replace the stationary blade with a drop of oil and properly align it. You're ready to go.
Apr 09, 2010 | Andis Master 01557 Hair Trimmer
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Loud andis master clipper
adjust power screw in one quarter turn
Apr 23, 2008 | Andis 01690 Hair Trimmer
1690 trimmer
Please send your clipper to the Andis repair department at 1800 Renaissance Blvd Sturtevant, WI 53177. If this clipper is less than a year old repairs will be done at no charge with a copy of the receipt. If the clipper is more than a year old there is a $6.50 service fee and $5.00 shipping fee, there may or may not be a charge for parts depending on what actually needs to be replaced. If you would like to talk with a customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Dec 22, 2007 | Andis 01690 Hair Trimmer
Andis Improved Master Hair Trimmer Logo
685 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
