Question about Compucessory CCS30222 (30222EA) Keyboard
Back and enter key not working - Compucessory CCS30222 (30222EA) Keyboard
    Problem Solver:
  • 7 Answers
Try your keyboard on another PC. If it still doesn't work then it's a hardware problem. Try to return it or get a replacement from the company.
Posted on May 26, 2011
Rang in 3.50 customer gave $10-when you enter amt tend you get error
turn the key to program and enter (0) , cash, then subtotal . then hit 3 subtotal, (0) cash, subtotal. turn the key back to reg and the cash key should now function correctly
Jan 07, 2014 | Casio PCR-T2000 Cash Register
Enter button not working
If this is a traditional keyboard (not laptop) or extremely fancy keyboard.
Try unplugging the keyboard. Then.
  1. Take a butter knife and slide it into the crevice next to the "enter key".
  2. Apply a small amount of pressure to pry the key upward.
  3. With little effort the key should pop off or slide off.
  4. Check the spot the key was for dirt, dust, food, etc. Clean it if you must. Make sure the actual key does not have anything stuck to the bottom of it.
  5. Push the key back onto it's place on the keyboard.
  6. Plug back in and see if that worked.
If this did not work, you may need to replace the keyboard OR you may want to make sure no viruses are playing an aweful trick on you.
Nov 22, 2013 | Roland Boss BR 900cd Digital Recorder BR...
Site that i should open my mms
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The phone has a four-way directional Navi key and two soft keys on either side of this. The Navi key can also be pressed in to select options.
  1. Press Menu (press Navi key)
  2. Highlight Settings and Select (press Navi key)
  3. Highlight Configuration and Select (press Navi key)
  4. Highlight Personal configuartion settings and Select (press Navi key)
  5. Press Add new(press Navi key)
  6. Highlight Multiedia msg. and Select (press Navi key)
  7. Highlight Account Name and Select(press Navi key), enter giffgaff - MMS then OK (press Navi Key).
  8. Highlight Server address and Select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002 and OK (press Navi key).
  9. Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
  10. Highlight Access point settings and Select (press Navi key)
  11. Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
  12. Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
  13. Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
  14. Highlight Bearer settings and Select (press Navi key)
  15. Highlight Packet data access point and Select(press Navi key), enter giffgaff.com and OK (press Navi key)
  16. Skip past Network type this should be set to IPv4
  17. Skip past Authentication type, this should be set as Normal
  18. Highlight Username and Select (press Navi key), enter giffgaff and OK (press Navi key)
  19. Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
  20. Press Back (right soft key) six times
  21. Highlight Messaging and Select (press Navi key)
  22. Highlight More and Select (press Navi key)
  23. Highlight Message settings and Select (press Navi key)
  24. Highlight Multimedia msgs. and Select (press Navi key)
  25. Highlight Configuration and Select (press Navi key)
  26. Highlight Configuration and Select (press Navi key), highlight Personal config. and Select (press Navi key)
  27. Highlight Account and Select (press Navi key)
  28. Highlight giffgaff - MMS and Select (press Navi key)
  29. Press the right soft key five times to get back to the standby screen
Please switch your handset off and back on again before using these settings.
The settings are now complete.
hope that helps
May 29, 2013 | Nokia C1 Cell Phone
Does not internet
Hi jobmasai,
you may wanna try this:
Nokia 2330 GPRS and WAP / Internet Settings
1.Press Menu (press Navi key)
2.Highlight Settings and Select (press Navi key)
3.Highlight Configuration and Select (press Navi key)
4.Highlight Personal configuartion settings and Select (press Navi key)
5.Press Add new (Navi key)
6.Highlight Web and Select (press Navi key)
7.Highlight Account Name and Select (press Navi key), enter giffgaff WAP GPRS then OK (press Navi Key).
8.Highlight Homepage and Select (press Navi key), enter http://giffgaff.com/mobile then OK (press Navi Key)
9.Highlight User name and Select (press Navi key), enter giffgaff then OK (press Navi key)
10.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
11.Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
12.Highlight Access point settings and Select (press Navi key)
13.Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
14.Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
15.Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
16.Highlight Bearer settings and Select (press Navi key)
17.Highlight Packet data access point and Select (press Navi key), enter giffgaff.com and OK (press Navi key)
18.Skip past Network type this should be set to IPv4
19.Skip past Authentication type, this should be set as Normal
20.Highlight User name and Select (press Navi key), enter giffgaff and OK (press Navi key)
21.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
22.Press Back three times (right soft key)
23.Highlight giffgaff WAP GPRS and press Options (left soft key)
24.Highlight Activate and Select (press Navi Key)
25.Press Back (right soft key) four times.
Apr 14, 2011 | Nokia Classic 2330 Cell Phone
The enter key on my 9-month-old Acer netbook has stopped working. I'm running a full scan as I type this and I've upgraded to Firefox 4 with no success. Is the key just worn out or is it a software...
This is likely a hardware problem, and not related to any of your software.
Keyboards take a lot of abuse and can wear out or get jammed. Crumbs from food, or dust, etc can also get lodged under the key. Fortunately the keys are removable, but you must be careful when removing them from the laptop (the plastic pins that hold them are delicate).
Using a table knife, slide it under the edge of the Enter key. Twist the knife a little to lift up one end. Twist gently until you hear a click as it comes loose. Be gentle and proceed slowly. Some Enter keys have two clips, so you may need to pry up the other end of the key too. Some keys also have a thin metal bar/wire. Notice how this hooks up, because you'll need to put it back together this way.
Look for any hair, crumbs or other items in the space under the key. Also, make sure the plastic/rubber spring-pad is working properly by pushing down on it. If you push on the spring-pad with a pencil (erase end), does the enter key work (open up Notepad or Word while you test this).
If yes, try putting the key back on the way it was. Hopefully everything should work now. If not, make sure you clicked it back in all the way, and that it is seated properly.
If it still doesn't work, there may be other problems with the key, and the best bet is to have a qualified technician take look. Take your system to wherever you bought it, or Best Buy for service.
Apr 04, 2011 | Computers & Internet
Just say unable to clean 35. nothing is working
Hi there you can try this not know if it will work for you but it works with some brother printers
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times until the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. Press the stop/exit key to return to the initial stage of the maintenance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Brother MFC 490cw Color Inkjet...
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
Help!!
Try pulling out adjacent keys and then put the enter key back . The smaller keys can then easily be fitted back.
Feb 06, 2008 | Compaq Presario M2000 Notebook
Compucessory CCS30222 (30222EA) Keyboard Logo
62 people viewed this question
Top Compucessory Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
Are you a Compucessory Computer and Internet Expert? Answer questions, earn points and help others
