Need instructions on how to reset factory defaults for network.
  • Office Equip... Master
  • 824 Answers
Without telling us the make and model number you cannot be helped. post again please.
Posted on May 26, 2011
Need to reset password....lost cd....can not connect to network
See if you can find instructions for your router. You need to do a factory reset, sometimes called restoring factory defaults. The method for doing that depends on the make and model of your router.
Aug 25, 2015 | Computers & Internet
Resetting to factory default (or resetting admin pasword)
You can do it manually. Or you can do it with a 3rd party software. Have done it many times with third party software. Never manually.
Here are the instructions on how to do it. These instruction come from Microsoft. 6596b083-3eaa-425a-b6b0-703252a5f2a3.jpg
Aug 01, 2014 | Freecom 32969 1TB XS LAN/USB 2.0 Network...
I need a code for a kodakhero printerphotocopier 7.1
I don't believe that model has a password. You may just need the password for the network you are using. If you want to reset the unit to the factory defaults see below.
To reset defaults to the factory default settings:
1. Press .
2. Touch , then touch Printer Settings.
3. Touch , then touch Reset All Settings.
4. When you see the message, "This will reset printer settings to factory defaults,"
touch Yes.
NOTE: Resetting factory defaults does not change the date and time, language, or
country/region.
Jun 19, 2014 | Netflix
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Forgotten password and username to access router
If you forget the password, you need to reset the device to the factory default settings. In that case, all configuration settings of the device are lost then you need to reconfigure the router,
To reset the device to factory default settings, follow the instructions from this link,http://global.dlink.com.sg/site_support/DSL-2640B/Manual/DSL-2640B_manual_v2.pdf
11_20_2011_12_11_30_am.pngHope this helps.
Nov 07, 2011 | D-Link - DSL-2640B Wireless Broadband...
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
My wirelee network is open i neep to reset password but lost instructions to do it
You can reset the Linksys back to the factory defaults.
Press the pinhole RESET button on the backof the router for 30 secs with the power on
Connect a LAN cable from the computer to the router , open a IE browser and tpye the configuration URL.
http://192.168.1.1
The default login and PW = admin
You can now change the default password and setup the wireless settings etc.
To secure your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 18, 2010 | Linksys Wireless-G Broadband Router
Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
May 10, 2010 | NetGear GSM712 Managed Gigabit Ethernet...
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
76 people viewed this question
jasbo
jasbo
