Question about Acer Computers & Internet
Not reading correct free space on file system udf, firmware is 1.06 reads and loads files ok but shows disk capacity that of files held and there is spare capacity on disk but continually shows frees pace 0 bytes. the same with any dvd-rw but these discs read ok in my office pc.
  • 817 Answers
You have a problem with windows and you should run chkdsk /r from the command prompt. place your windows disk on the dvd drive as it will be needed to correct any damaged system files. If this does not cure then it would probably best to reinstall Windows a fesh.
Posted on May 26, 2011
My external hard drive shows up in devices but i cannot access the files on it. The laptop does not recognize it as a hard drive
C:\Documents and Settings\mpos>chkdsk c:
The type of the file system is
NTFS.
WARNING! F parameter not specified.
Running CHKDSK in read-only
mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification
completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index
verification completed.
CHKDSK is verifying security descriptors (stage 3 of
3)...
Security descriptor verification completed.
CHKDSK discovered free
space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK
discovered free space marked as allocated in the volume bitmap.
Windows found
problems with the file system.
Run CHKDSK with the /F (fix) option to correct
these.
156280288 KB total disk space.
12116176 KB in 34467
files.
11304 KB in 4337 indexes.
0 KB in bad sectors.
110084 KB in use
by the system.
65536 KB occupied by the log file.
144042724 KB available
on disk.
4096 bytes in each allocation unit.
39070072 total allocation
units on disk.
36010681 allocation units available on
disk.
THIS IS WHAT I GET WHEN I
TYPE IT IN. WAIT A FEW MINUTES WHEN U TYPE CHKDSK E:OR TYPE IN
TYPE IN
CHKDSK E: /F
Sep 15, 2013 | SimpleTech 320GB SimpleDrive External by...
Just bought from a LG CH10LS20 bluray player; installed it on a Windows XP - it reads all dvd, but not bluray; i tested it on a windows 7 and everything is great. the error on win XP is: "windows...
Hello there,
you are right, Win Xp is not Blu-Ray compatible unless you installed UDF reader. UDF reader is a driver which lets you explore Blu-ray and HD-DVD UDF v2.5 disc in Win XP's file explorer.
Click the Link to download UDF v2.5 driver
1. After downloading extract the file to any folder.
2. Right click on thdudf.inf and choose Install.
3. Once this is done, reboot your machine.
4. After reboot your system will be able to read the new UDF 2.5 file system recognition.
5. If you want your system to read video files, you have to download codecs.
Codec Link download.
Thank you for using FixYa.
Hopefully this information helps.
Jul 27, 2011 | LG Electronics CH10LS20 LightScribe 10x...
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
When a computer takes time to start what do you think is the problem.
Uninstall (not simply delete) all unused applications. These programs take up space on the hard drive and reduce the area for temporary files and load the Windows registry with dozens or even hundreds of file that need to be loaded at boot time. Both of these situations can drastically slow a computer down during boot and while running.
Perform some disk "housekeeping". Run Cleanup to remove old temporary and orphaned files, cookies, etc. Read the directions carefully before using.
Run the Windows Disk Defragment Program. It is a tool for each hard drive. This program consolidates data and free space so that the disk has large, unbroken blocks of unused space to write temporary files - and makes reading data easier as it can be found in one place - instead of having to hunt all over the disk to find it.
Remove existing and prevent future "****" from collecting by using Ccleaner aka "**** cleaner". When run and set up correctly, it will remove and prevent accumulation of junk files and spamware. Again, read directions carefully and allow updates to the program for maximum protection.
Lastly, install a good Anti-Virus program. Norton stuff is very good, BUT can slow a machine down considerably. Other choices are Avast (free "Home" version available) or Viper for about $30. Both are very good to excellent and have minimal impact on the computer speed.
Doing these few items should help a great deal - please rate this reply and good luck!
Sep 02, 2010 | Dell Dimension 4600 PC Desktop
I want to format a cd read only disk as a UDF file. How is it done
If it's a READ-ONLY as you say then absolutely nothing can be written on it, including a file system.
If it's a Recordable (once only) disk then it can't be formatted.
For a disk to be formatable it must be ReWritable.  The option to format (and which format to use) a cd-rw is in the menu of the burning soft or use Nero's special formatting tool InCD. A DVD-RW is formatted to UDF by default.
Jun 03, 2010 | Computers & Internet
KINGSTON removable disk error
Find and check real free space go to my computer and right click your driver letter and click properties it will show what is real ammount of disk. For one 4GB file it must not be problem but for meny little file can take more space besider their sum of capacity is 4GB. At format check correct ammount of data "capacity" is 8GB (7.9) also file system for NTFS or FAT32. FAT cant bear 8GB.
Aug 04, 2009 | Computers & Internet
How do I play a UDF file on a Cyberlink PowerDVD DX8? I am using a virtual disk and a virtual drive. The drive will read it fine but the player will not.Do I need a codec?
You may not be able to play UDF file. But you can rip the file, and download a file converter program and
then burn it on a disc in AVI or DVD file.
If it is on a computer, than you should be able to download a UDF codec
Jun 22, 2009 | CyberLink Power DVD DX 8.0 for PC
SanDisk 2.0GB disk full - but it's not full!
1. Right click My Computer and select Manage.
2. Open the Device Manager and find your USB drive under the Disk Drives heading.
3. Right click the drive and select Properties.
4. Choose Policies tab and select the "Optimize for performance" option.
Click OK.
6. Open My Computer.
7. Select Format on the flash drive.
Hurrah there is NTFS option available now
8. Choose NTFS in the File System dropdown box.
9. Device Formatting is completed.
Important: To remove a device safely without data loss use a "safely remove hardware" procedure or Eject function from Windows Explorer.
Apr 04, 2009 | Electronics - Others
Mixmax froze
The memory may be corrupt and it can't read the music files correctly. Open your My Computer icon and plug the player into your computer. You should see a new removable disk called Mix Max appear. Right click on the disk and choose Format from the pop up menu. At the Format window make sure that the File System is set to FAT32 and click Start. At the next window click OK to proceed. You'll then need to add the songs back to your player but it should correct the problem. When adding the songs to the player again make sure that you leave at least 4 megabytes of space available so it can create the library file.
Mar 06, 2008 | Disney Mix Max Digital Media Player
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
