Question about Kenmore Dryers
Mod.#110.95876400 no power at gas valve or ignighter thermostat tested ok
    Master:
    Sergeant:
  • 385 Answers
You might want to check your door switch.
Posted on May 26, 2011
Samsung Gas Dryer model DV328AGW/XAA, not getting gas to ignighter,
Could be a defective igniter, thermocouple, or gas valve
Mar 06, 2017 | Samsung Dryers
BLUE PRINT FOR A TELEDYNE LAARS MODEL NO ESC250P
check gas pressure if ok check gas pressure on gas valve might have to adjust gas valve if new at this call a professional
Jan 15, 2013 | Teledyne Laars Pool & Spa
Pilot ignights, keeps sparking then goes to lockout
I have the exact same model with the exact same problem. Did you ever figure out what the problem was? I just picked up a new gas valve, but maybe i should check the flame sensor first. In my systems case the electronic ignition fires, which lights the pilot, but it keeps firing even though the pilot light is lit. So I think it could be the flame sensor, how do I remedy that or check it out. I would like to check this out first before dropping in the gas valve, cause they arent cheap and I can still return it before its installed.
Jul 11, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have a wall oven and the power goes on but no gas smell or anything no flames no nothing i think its the ignighter what do u think please help
Yes, ignitor problem. Some ignitors are easy to replace and some are hard to install. If you know how to test for voltage at the ignitor and a pretty handy, you can replace the ignitor yourself. Call your parts house and order a new ignitor using the model number. Ask if they have a cheaper generic replacement. Replace the ignitor and test. So far, every gas range I have worked on with this problem, has been a bad ignitor. You can also have a bad oven control, sensor, thermostat, valve, or wiring problem. Unlikely however. Good Luck, Appliance Specialists.
Jan 19, 2010 | Ovens
My oven won't turn on it will not ignite and I dont hear the gas flow. Can you please help me?
i recomend a qualified licenced gas applince repair tech
but first do u see the ignighter light up
is it white hot not yellow or orange
if not white hot should be replaced buy a qualified licenced tech
if it is white hot hard to look at then u need to test the electrical components safety valve oven thermostat clock limit thermostates to determon the cause of your problem
(solv ya prob)
Oct 18, 2009 | Maytag Ovens
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
Hotpoint gas oven 5yrs old pre heats fine but then doesn't keep temp up.
You have either a faulty oven thermostat, or your oven door seal is faulty. You can check the oven door seal by doing the following (you will need a A4 piece of paper):
Open the door put the paper against the seal, close the door. Now pull the paper slowly out, if there is resistance then the seal is fine.
The oven thermostat test is as follows (you will need a stopwatch):
Turn your oven on to the lowest setting,when it goes to high flame start timing it the oven should cut down within 8 minutes, if this doesn't occur your stat is faulty.
I hope this helps
Jul 06, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Gas dryer don't heat, pilot ok
The ignitor is coming on so that means you have power to the gas assembly. Next the flame sensor should shut down the ignitor when the bi-metal inside it bends from the heat. This kills power to the ignitor, which allows for the power to activate the coils. The coils snatch open the gas valve and allow for ignition. The raw gas hits that screaming hot ignitor and ignites into a glorious flame, raising the temperature inside the drum. While that flame is on, the control thermostat is monitoring the heat within the drum. When the temperature gets to a round 140 F then the power gets killed to the gas assembly by the control thermostat. If all of that seems to be happening for say, the first time, then suddenly the ignitor comes on then shuts down and no flame comes out, then you have weak and intermittant coils. Replace these puppys:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 16, 2008 | Dryers
Dryers Logo
46 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
