Tone of red is showing too much. like a red shadow behing people
  • 53 Answers
Try this: go to the menu go to picture change the tint by adjusting the red.
Posted on May 26, 2011
After lamp change, why do flesh tones have red and green shadows?
Make sure the lamp is seated properly and also make sure the Lamp uses an Osram or Philips Bulb inside. If it is a knock off no name that may be the problem as they do not reproduce color properly
Sep 19, 2015 | Mitsubishi 73" DLP 1080p 120Hz 3D WD73640
Our 7 year old Sony TV KP-51W5510 has the following problem. Picture has 2 colors, writting has 2 colors the skin tone has 2 colors, writting on the screen will show 2 colors black and red in shadows pls...
a ladha,
You have lost the convergence circuitry. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will explain the problem, tell you where to get parts and explain how to do the repair.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Sony KP-51WS510 51" Rear Projection...
How to take of steering wheel in audi 80
First you have to disarm SRS system.How- ensure ignition switched OFF.Remove ign.key.Disconect battery earth lead and make sure accidental reconection is not possible.Disconect power suply multi-plug/red/,located behing driver.s storige compartment under fascia.No waiting time required. Now you have to remove driver.s airbag.There is two screws with 5mm allan/hexagon/head behing an airbag.Open it.Disconect and remove airbag.Use 24 socket for steering wheel nut. When remove a steering wheel be very carefull with spiral cable behing.GOOD LUCK !!! There is tightening torque for steering wheel nut-40Nm and two screws-6Nm.
Apr 24, 2010 | 1991 Audi 80
Panasonic PT47WX54J is showing a red shadow behind words and pict
you need to go to your remote, look up menu. then select "convergence"...this will give you a "crosshairs pattern to align your "guns" ...it has three red, blue, and green.....try not to move the TV around too much....its knocking them out of alignment
Oct 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Black and white negatives produce scans that show too much contrast......any suggestions?
1) Decide which problem is the worst: shadows too dark or highlights too light. 2) Run your scan with Nikon 4 software tool "Digital DEE" adjusted for EITHER Shadows or Highlights (not both; Highlights setting will "trump" a Shadows setting, even though you have a non-default setting at all DEE sliders).  Generally good choices for Shadows are 39 to 55. (39 = lighten the shadows a little; 55 = lighten the shadows a lot.) Experiment; do several scans. Generally good choices for Highlights are about 17 to 42 for amount and about 4 to 30 for threshold. (17/4 = dim the highlights a little; 42/30 = dim the highlights a lot.) Again, you have to experiment to get some experience. 3) When in Photoshop PSD format (After first doing a Levels adjustment): Try using the Adjustments/Shadows and Highlights tool to AGAIN brighten your too-dark shadows and/or tone down your highlights. (I.e., the effect is cumulative on top of your Digital DEE effect. But Digital DEE is a more "magical" feature and is somewhat preferred to PS's Shadows and Highlights tool. DEE, however, will often produce an annoying "light smear" [bright area "dragged" into an adjoining darker area]. In case of a "light smear" from DEE, do not use the tool; too hard to fix.  Use PS's Shadows & Highlights tool instead.)  4) Proceed with other PS adjustments such as Curves, etc.  5) Still not satisfied?  Go to Levels again and look at your histogram. Is it really "stacked" to one side or the other (a mountain way over at the left or at the right)? You might want to try the rather severe command of Adjustments/Equalize.  This "spreads out" your pixels more evenly across the histogram. Note: this is a scary adjustment that requires misc fixes to tone-down certain aspects of the Equalization adjustment.  No free lunch, right? 6) After experimenting with the above tools, you should be able to get a handle on too-contrasty pictures. There will be a learning curve.
Sep 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Red and green shadows
Your tv has a convergence board problem. Have a technician replace the convergence IC's.
Jul 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Red lines taking over my T,V
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 26, 2006 | Samsung HCM5525W 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
