Question about GE Televison & Video
I can not get the TV input button to work on my Direct Remote contoll
  • 4 more comments
  • idpetersburg May 26, 2011
    I will find out this information and send it tomorrow, I am not at home
    The remote is Direct TV model tv is GE
    the model is the white direct remote controll
    the TV is a GE
    The Remote # is RC64
    The TV # is GE 27GT273
    How do I find the five digit code out of the 19 five digit codes you sent me
  • idpetersburg May 27, 2011
    How can I get the correct code number for my GE tv
  • 8,197 Answers
MAy I get the model # of the remote to help you more. Also will need the make of the TV to get you the codes to program the remote.
Posted on May 26, 2011
  • 6 more comments
  • Jyackle5
    Jyackle5 May 26, 2011
    Ok need to get the remote # it will be lick RC65. If the remote is white it will be on the face upper left corner. I will be here till 8:00 pm PST If you would like to get back to me today.
  • Jyackle5
    1. Turn on the TV.
    NOTE: Please read steps 2-5 completely before proceeding.
    Highlight or write down the codes and component
    you wish to set up before moving on to
    step 2.
    2. Locate the 5-digit code for your TV. (Below)
    3. Slide the MODE switch to the TV position.
    4. Press and hold the MUTE and SELECT keys at the same
    time until the green light under the TV position
    flashes twice, then release both keys.
    5. Using the number keys enter the 5-digit code for your
    brand of TV. If performed correctly, the green light
    under TV flashed twice.
    6. Aim the remote at your TV and press the PWR key
    once. Your TV should turn off. If it does not turn off,
    repeat steps 3 and 4, trying each code for your brand
    until you find the correct code.
    7. Slide the MODE switch to the DIRECTV position. Press
    TV POWER. Your TV should turn on.
    11447, 10047, 10051, 10451, 10178, 11922, 11919, 11917, 11347, 10747, 10282, 10279, 10251, 10174, 10138, 10135, 10029, 10027, 10021
    Once your remote is setup to work with your DIRECTV Receiver, you you can set it up onscreen by pressing MENU, then SELECT on Settings, Setup in the Quick Menu, then selecting Remote from the left menu.
    1. Turn on the TV.
    step 2.
  • Jyackle5
    Tha last post was for the rc65. Here is how to set up for the rc64
    Once your remote is setup to work with your DIRECTV Receiver, you can set it up onscreen by pressing MENU, then SELECT on Settings, Setup in the Quick Menu, then selecting Remote from the left menu.
    Here is the manual setup.
    1. Turn on the TV.
    step 2.
    2. Locate the 5-digit code for your TV. (codes below.)
    8. For future reference, write down the working code for
    your TV in the blocks below:
    11447, 10047, 10051, 10451, 10178, 11922, 11919, 11917, 11347, 10747, 10282, 10279, 10251, 10174, 10138, 10135, 10055, 10029, 10027, 10021
    1. Turn on the TV.
    step 2.
  • Jyackle5
    If you would like the manual for the remote please ask and I will send you the link to the manual
  • Jyackle5
    Read steps 5 and 6. There is now way I can say what code it is. You will need to try all codes till a code works.
  • Jyackle5
    Jyackle5 May 28, 2011
    If you were unable to find the code for your brand of TV or
    component, you can try a code search. This process may
    take up to 30 minutes.
    1. Turn on the TV or component. Insert a tape or disk if
    applicable.
    2. Slide the MODE switch to the TV, AV1 or AV2 position,
    as desired.
    3. Press and hold the MUTE and SELECT keys at the same
    time until the green light under the selected switch
    position flashes twice, then release both keys.
    4. Enter
    9-9-1 followed by one of the following fourdigits:
    COMPONENT TYPE COMPONENT ID #
    Satellite 0
    TV 1
    VCR/DVD/PVR 2
    Stereo 3
    5. Press PWR, or other functions (e.g. PLAY for VCR) you
    want to use.
    6. Point the remote at the TV or component and press
    CHAN up. Repeatedly press CHAN up until the TV or
    component turns off or performs the action you
    selected in step 5.
    NOTE: Every time CHAN up is pressed the remote
    advances to the next code and power is transmitted
    to the component.
    7. Use the CHAN doun key to step back a code.
    8. When the TV or component turns off turns off or
    performs the action you selected in step 5, stop
    pressing the CHAN up key. Then, press and release the
    SELECT key.
    NOTE: If the light flashes 3 times before the TV or component
    responds, you've cycled through all
    codes and the code you need is not available. You
    must use the remote that came with your TV or
    component.
    applicable.
    as desired.
    4. Enter
    Satellite 0
    TV 1
    VCR/DVD/PVR 2
    Stereo 3
    want to use.
    selected in step 5.
    to the component.
    SELECT key.
    component.
  • Jyackle5
    Middle of page 10 on the manual above/link above you can learn how to search for your TV. Or you can go to the link below page 10 to find out how to search for your TV.
    http://www.directv.com/learn/pdf/Remote_...
  • Jyackle5
    Also is it a TV/VCR, TV/DVD that might me help you find a code. Or give me the model # of the TV so I know what you have.
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
How do I switch the Input Select to watch a movie when the button doen't work?
I recommend getting a universal remote to replace your tv remote.
Apr 28, 2014 | Symphonic ST420FF 20" TV
My TCL TV has a blue screen saying no signal. What button do I push on my new universal remote to get my cable tv
the button will be labeled either source, input, tv/video. if the direct TV remote was programmed for your television there is a tv/input button
Nov 03, 2013 | Televison & Video
Cant get the remote to work for menu options just started setting it up already programed to my direct tv remote now nothing is working or either remote t.v or direct tv remote
To diagnose a remote control problem follow these steps.
1) unplug the TV power cord, count to five and plug it back in. (reboot)
2) try to power on with ORIGINAL MANUFACTURER remote.
if that works- your TV and original remote are fine.
if that does not work:
4) try to power on with buttons on the TV itself- if it works- check your remote batteries and try remote again.
Direct TV and Dish Network remotes will ONLY operate SIMPLE function of your TV such as power, volume, input.
They will NOT access your TV menu.
Apr 12, 2011 | Televison & Video
I recently switched from direct tv to cox communications. My tv is stuck on the incorrect input and my remote works perfectly except the input button and the menu button. I tried a different univeral...
Check For Sticky Button On The TV Set Possibility Issue with your Command Panel Press any individual button and check carefuly for Sticky button If not Some TV set got Child Protecton lock on it check if your Signal from the TV set it On Remote Mode .
Sep 22, 2010 | Televison & Video
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
I just got a 37 inch flat screen. I had it working with my direct TV box. My son pushed a button on the remote and now it will not connect to the direct TV. I need some help.
You will need to look for your input button on the tv or the remote and look at the back of your tv to see where your wires go!!!
You would make sure that the wires go to (input 1) are input2
Then you put your input on input1 are input2 and your wires in input1 are input2 on the back of the tv.
Feb 17, 2010 | Insignia 37" LCD Flat-Panel HDTV
Got a 32 inch dynex tv how do you get the direct tv to work on it
the tv or direct tv comes with the hook-up cables. try one of those and remember the TV input where you plugged in the direct tv box then on TV remote or front function button change the input. :)
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Aug 17, 2009 | Directv RC-64 Remote Control
Televison & Video Logo
49 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
