Question about Husqvarna Zero Turn Mower Z5426
Drive belt for Husqvarna RZ5424 mower came off and it doesn't show in manual how to put it back on properly
  • 42 Answers
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Mar 15, 2009
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
trippssmengi
  • 76 Answers
SOURCE: diagram of belt replacing on 21h 48 in cut husqvarna riding mower
You can try http://www.usa.husqvarna.com click on support and then product manuals. There you can find a diagram for your machine that could possibly help.
Posted on Mar 28, 2009
SOURCE: How do you replace a drive belt on a husqvarna cz4817
i just replaced my belt on a cz 4817. On one side there should be a bar with a spring on it. If you sitting in it it will be on you left side mounted on the deck itself. Push the bar in for about an inch and then up over the lip thats the belt tension spring. you should now be able to remove your old and put the new on. If you need the diagram to show you how to lace the new belt let me know and i will email it to you. good luck
Posted on Jun 16, 2010
The left operating handle does not turn the mower at all. Could it be a belt problem?
Sounds as if the Hyrdrostatic pump may have a stuck valve, or could just need replaced.
May 14, 2016 | Husqvarna Garden
Do I tighten a ground belt from a 2011 Husqvarna rz5424 zero turn lawn mower?
There is not an "adjustment" tension is held by an idler pulley. If the belt is too loose, you must change it.
Aug 09, 2015 | Husqvarna Garden
Diagram to replace drive belt for RZ5424
the library section 629 has many manuals for auto and small engine--or buy one online--may need special tools--if tu much to handle bring it to an independent guy
Mar 02, 2015 | Husqvarna Garden
Have husqvarna model 93605500/a25h54 need diagram for drive belt
If you go to www.Husqvarna.com/us you can put in your model number and get an IPL or owner's manual this will show you how the belt fits on the tractor.
Sep 19, 2014 | Husqvarna Garden
WHEN I MAKE A RIGHT TURN WITH MY HUSQVARNA RZ5424 IT JUST MAKES A GRINDING NOISE AND DOES NOT GO WHAT COULD BE MY PROBLEM?
Where is the grinding sound coming from??? Could be your hydrostatic transmission. When one side goes the other will follow... Time for a new mower... Mine lasted 3 years...
Jul 29, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
How do I change the drive belt on a 7021r mower? The drive will move the mower on pavement but not on the grass
First, you need to make sure you have the right tools for the job. You'll need a wrench, work gloves, mower blade clamp, drain pan and fresh fuel. Check your owner's manual for the correct belt to your specific lawn mower. Belts that are not specifically designed for your mower will not fit properly and may wear down prematurely. Next, remove the spark plug wire. This is a safety precaution to prevent the mower from accidentally starting.
Now you can remove the screws that secure the drive cover to the mower deck. Once you've taken off the drive cover, loosen the screw that holds the belt tension spring to the transmission. As the screw is loosened, tension on the belt is released allowing you to remove the belt off of the front transmission pulley.
At this point you'll need to turn your mower on its side to take off the mower blade. Be sure to use a work glove to protect your hand when removing the mower blade. You can use a lawn mower blade clamp over the blade to secure it. Unscrew the bolt to remove the blade and then the engine baffle. Once the pulley unit is exposed, you can remove the entire drive belt. Insert the new drive belt and place one end on the rear pulley and re-attach the engine baffle. Then, place the mower blade back (making sure it's facing the correct way with bottom of the blade facing the ground) and tighten the bolt. Remove the clamp and return the mower to its upright position so you can place the other end of the belt to the front pulley. Remember to tighten the screw to the tension spring.
Put the front drive cover back on, tighten the screw that secures the cover to the deck and reconnect the spark plug wire. Add new fuel to your mower and you're done!
May 14, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Husqvarna Zero Turn Mower Z5426 Logo
2,039 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
