Question about Hannstar I-Inc iF191DPB 19" LCD Monitor
Hannstar IH252HPB 25" LCD monitor has 2 burned
    Genius:
  • 1,126 Answers
Go to www.partstore.com to get new parts for your set.
Posted on May 26, 2011
  • damitalbert May 26, 2011
    Unfortunately I could not find any reference to the monitor manufacturer I-INC (Hannstar) in thehttp://www.partstore.com data base. Do you know any other parts supplier that might.
    Thanks
  • Veril Gillette
    Veril Gillette May 26, 2011
    You can just take the power supply board to a electronic tech, at a repair shop, and ask them to repair your power supply, that will be cheaper than haveing the whole set repaired.
Acer flat screen monitor
acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
May 03, 2013 | Acer S202HL LCD Monitor
I have a problem with the ET1725L-7CWF-1-G touch screen rom ETOL. The problem started as it powers up for seconds and then shuts down. I sent it previously to a test center to be checked and they said that...
you need to replace your power supply! asap!!! check the voltage coming from the ac adapter to verify the correct voltage!! please vote and rate this post!!! thanks
Dec 02, 2010 | Elo 17' LCD MONITOR, TOUCHSCREEN, 1280 X...
I have a 19 inch I-INC monitor about 2 yrs old. Usually a few minutes after start up monitor will go black for 30 to 60 seconds. It will then relite and stay on indeffinately. Cannot decide whether...
Try it on another PC.
Otherwise it can be failing power supply due to bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 11, 2010 | Hannstar I-Inc iF191DPB 19" LCD Monitor
I-inc monitor stopped displaying Model YP999; Type CY199DP
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 03, 2010 | Hannstar I-Inc TW-191D Monitor
Black screen power light flashes
Try it on another PC and check the VGA cable fiist.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 21, 2010 | Hannstar I-Inc TW-191D Monitor
Vertical n horizontal ic
Are you asking about this LCD Daewoo (F227B) monitor? LCD monitors do not use Vertical/Horizontal IC like the CRT type for the H/V Yoke.
What is the problem with the monitor?
Common problem with LCD monitor:
May 19, 2010 | Daewoo F227B Monitor
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
Feb 24, 2010 | Hannstar I-Inc TW-191D Monitor
Open Questions:
Hannstar I-Inc iF191DPB  19" LCD Monitor Logo
481 people viewed this question
Top Hannstar Computers & Internet Experts
David Payne
David Payne
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
