Question about Sony RDR-VX420 DVD Recorder/VCR
Vcr tape will not eject - Sony RDR-VX420 DVD Recorder/VCR
    Sergeant:
  • 217 Answers
Try unplugging the unit and re starting it.You can also lift the front cover and try pressing in, down while pressing the eject button.
Posted on May 26, 2011
Testimonial: "thanks"
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
VCR tape won't eject
The reason your tape wont eject is either because, it is stuck or the tape run loose inside of it.
To remove the tape, unplug the VCR, then unscrew it open, you will have direct access to the tape, so try to plug it back and press eject, when it gets stuck, apply a little force in pushing the tape up, to the height where it is to pass out, and it will eject your tape.
If you are not familiar with such activities, i will advice you get a repairman to get this done for you, in order for you not to damage any other part inside the VCR.
Take cacre and good luck
Oct 14, 2010 | Sylvania LV448HG VCR
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
VCR TAPE IS STICK IN VCR PLAYER.
if you can't get the tape out enough to pull it very carefully out by hand, you'll have to bring it to a repair shop. the tape is probably twisted up inside and jammed.
Nov 08, 2007 | Philips CCB092AT 9 in. TV/VCR Combo
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Sony RDR-VX420 DVD Recorder/VCR Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
