Question about Kenmore Dryers
Kenmore dryer is not drying clothes completely; ignitor will light and burner goes on for a few minutes and then shuts off. The ignitor goes on again and the burner will again light for a few minutes. Then the ignitor goes on for few minuites but the burner does not go on. The ignitor will light again but the burner does not go on. We have checked the lint filter & cleaned the vent hose for lint. When the dryer is shut off for a while, this same action repeats.
  • 1 more comment
  • btrflyem186 May 26, 2011
    Does this mean that the thermostat is open or is it closed when it gets to that 3rd cycle?
    Should I try to jumper out the thermostat to see if it works?
  • btrflyem186 May 27, 2011
    We did jumper out the Thermostats but this did not correct the problem Our parts break-down shows a picture of only one coil with it's parts #. The assembly itself actually shows 2 coils; one with blue & black wires on top of it and a black & white wires on the bottom portion of the coil. The other coil which is not called out on the parts list has a white & blue wire on it. Which one of these could be giving me the problem?
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this thermostat for continuity and if bad replace it as it cannot be reset. If it is fine then check the coils as the igniter and burner seem to be working fine...Hope this helps...please post back for further assistance.
Daniel
Posted on May 26, 2011
  • Daniel Scott
    Daniel Scott May 26, 2011
    Yes you can try to remove the thermostat and then connect its two wires together to see if thats the issue if not then it can be the coils
  • Daniel Scott
    Daniel Scott May 28, 2011
    Use a multimeter and check for the continuity in both the coils.
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Kenmore Dryers
Isn't heating up. takes forever to dry,
Disconnect the complete exhaust vent tubing and clean it out thorourghly. Then it will dry. There is a moister sensor in your dryer and when the lint builds up inside the vent tubing the sensor shuts off the burner to prevent fires from starting
Apr 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Partial drying
if it's a gas dryer you have bad gas coils,also you might need a clean out,if the air isn't blowing out of the dryer the clothes will not dry,you need to go outside and make sure the flapper is blowing fully open, if it's a long vent line that goes through the wall to reach the outside take the vent line off the back of dryer and blow it out with a leaf blower,then you need to clean out the duct that your lint filter slides into and then vac out the inside of dryer,you should clean it out or have someone come in to clean your dryer out at least once a year so you don't have a fire more so with gas cause you have an open flame in there,if it's gas,run the dryer and see if the ignitor is glowing and lighting the burner,check it again in like a half hour and if the ignitor is lighting the burner you have bad gas coils,if you need more help send the model number located around the opening where you put the clothes in the dryer and let me know if you need anything else
Dec 18, 2009 | Kenmore Dryers
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Gas dryer does not completely dry
Replace the glowbar ignitor and also the gas valve coils.
Aug 18, 2009 | Kenmore Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
101 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
