Question about HP DesignJet 500ps InkJet Printer
Managed to install AutoCad2000 on win 7 machine, got plotter to operate on all programs escept autocad2000--states Memory Allocation Error - and note a problem with the driver. I have installed the latest driver supplied by HP for this device. Any help will be appreciated.
  • HP Expert
  • 141 Answers
Try the Windows XP 64 or 32 bit driver. Make sure it is the PS driver. Happy plotting.
Posted on Jul 29, 2011
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
Dear Sir, Machine: Lenovo Ideapad Z560 (Blue Screen) Cannot start computer I had dual operating system XP & Win 7 on my computer, while using Internet (XP System) I got Memory Dump Error system...
your windows operating system is probably corrupt you cannot recover all of your files,
unless you have an file recovery software.
re format your disk c and put an operating system again.
Mar 21, 2011 | Lenovo IdeaPad Z560 Laptop Computer -...
HAVE INSTALLED WINDOWS 7 LIGTAMATE DISC CAME WITH THE MACHINE WHEN PURCHASED PROBLEM LIVE WINDOWS STARTS TO INTALL FOR ABOUT 58% AND THEN FAILS WITH A WINDOWS GENERATED MESSAGE TO TRY AGAIN MANY TRY...
Hi.
I feel your pain. Microsoft made this program, but it directly conflicts with the memory allocation, as well as parts of directx.
It appears that this problem is only with the windows 7 operating system.
The actual code description is access out of range, meaning that the program is supposed to call a certain amount and part of memory for it's usage, nut it is trying to use other areas of memory instead.
It's not that you have a bogus copy of windows, it's just a poorly designed application.
Right now, there is no current fix, unfortunately.
The best thing you can do is un-install it for now, and wait for microsoft to fix it in an update.
After all, installing only part of a program doesn't do any good.
Strange that it is only the windows 7 version, all others seem to work just fine.
I have it on my old xp system, and it works flawless on it.
I'm sorry that microsoft fouled up, and hopefully they will get this straightened out soon.
Feb 11, 2011 | Microsoft Windows Live OneCare 2.0:...
I purchased AVG but it didn't install properly so I cancelled the installation. Now how did I install the product I've already purchased? I have the license number.
Most probably it seems to be a low ram problem but you should match the specifications with your machine to find the culprit.
here are the specifications
Processor Intel Pentium 1.5 GHz Memory 512 MB RAM Hard disk free space (for installation) 750 MB HDD Recommended system requirements
Processor Intel Pentium 1.8 GHz Memory 512 MB RAM Hard disk free space (for installation) 1200 MB HDDI guess you lack something among them please verify them .
If you re still not able to resolve just comment with error message
Jan 18, 2011 | Computers & Internet
I am using toshiba l310 laptop with windows xp installed onit.NOW I WANT TO CHANGE MY OPERATING SYSTEM FROM XP TO WINDOWS 7,MY QUESTION IS THAT CAN I USE SAME DRIVERS FOR WINDOWS 7 WHICH I USE ON XP ...
You will need new drivers for Win 7. Before attempting to go to Win 7, run the Microsoft Upgrade Advisor and see what issues it lists: http://go.microsoft.com/fwlink/?LinkId=161223 (since laptops have on-board video that may be an issue). You will be doing a custom install from XP and have to reinstall all of your programs and drivers - many will be available. Several XP programs will not install in Win7 without some work (compatability mode or the XP mode virtual machine (in Pro or Ultimate). Upgrading your software may be needed unless you have the latest version that supports XP through Win7 or want to do the work-arounds.
In addition you would be wise to check for any BIOS updates for your specific machine and apply those. Windows 7 is a good OS if you have 2 GB or more of memory. It can run with less but it isn't better than XP in that case. The biggest difference is that Win7 will be supported by Microsoft for updates for a longer period (patches); XP will lose that support in the next few years.
I hope this helps.
(I converted an XP desktop to Win7. However, my video card could handle the OS and I have 2.5 GB of memory and a Windows Experience Index of 3.9 from the system.)
Feb 15, 2010 | Computers & Internet
Win xp error code 0 x 80090006 after win update
Some times this problem occurs.You dont worry.you will update after some days.Now you can do the bellow steps
start->all programs->accessories->system tools->system restore->restore my computer earliar time ->
then choose the best cheak point .then ok->close.
wait 10 to 20 minutes. your system automaticaly restored in previous state.(Before Updated state).
Note: You must chose the date before update the windows.(Cheakpoint)
Feb 13, 2010 | Microsoft Windows XP Professional
How to be solve banker algorithm?example
I m providing you this from my college notes
Banker's Algorithm
* multiple instances of resource types IMPLIES cannot use resource-allocation graph
* banks do not allocate cash unless they can satisfy customer needs when a new process enters the system
* declare in advance maximum need for each resource type
* cannot exceed the total resources of that type
* later, processes make actual request for some resources
* if the the allocation leaves system in safe state grant the resources
* otherwise, suspend process until other processes release enough resources
Banker: Data Structures define MAXN 10 /* maximum number of processes */
#define MAXM 10 /* maximum number of resource types */
int Available[MAXM]; /* Available[j] = current # of unused resource j */
int Max[MAXN][MAXM]; /* Max[i][j] = max demand of i for resource j */
int Allocation[MAXN][MAXM]; /* Allocation[i][j] = i's current allocation of j*/
int Need[MAXN][MAXM]; /* Need[i][j] = i's potential for more j */
/* Need[i][j] = Max[i][j] - Allocation[i][j] */
Notation:
X <= Y iff X[i] <= Y[i] for all i
(0,3,2,1) is less than (1,7,3,2)
(1,7,3,2) is NOT less than (0,8,2,1)
Each row of Allocation and Need are vectors: Allocation_i and Need_i
Banker: Example
Initially:
Available
A B C
10 5 7
Later Snapshot:
Max - Allocation = Need Available
A B C A B C A B C A B C
P0 7 5 3 0 1 0 7 4 3 3 3 2
P1 3 2 2 2 0 0 1 2 2
P2 9 0 2 3 0 2 6 0 0
P3 2 2 2 2 1 1 0 1 1
P4 4 3 3 0 0 2 4 3 1
Banker: Safety Algorithm
* consider some sequence of processes
* if the first process has Need less than Available
* it can run until done
* then release all of its allocated resources
* allocation is increased for next process
* if the second process has Need less than Available
* then all of the processes will be able to run eventually
* IMPLIES system is in a safe state
STEP 1: initialize
Work := Available;
for i = 1,2,...,n
Finish[i] = false
STEP 2: find i such that both
a. Finish[i] is false
b. Need_i <= Work
if no such i, goto STEP 4
STEP 3:
Work := Work + Allocation_i
Finish[i] = true
goto STEP 2
STEP 4:
if Finish[i] = true for all i, system is in safe state
Banker: Safety Example
Using the previous example, P1,P3,P4,P2,P0 satisfies criteria.
Max - Allocation = Need <= Work Available
P1 3 2 2 2 0 0 1 2 2 3 3 2 3 3 2
P3 2 2 2 2 1 1 0 1 1 5 3 2
P4 4 3 3 0 0 2 4 3 1 7 4 3
P2 9 0 2 3 0 2 6 0 0 7 4 5
P0 7 5 3 0 1 0 7 4 3 10 4 7
10 5 7<<< initial system
Banker: Resource-Request Algorithm
STEP 0: P_i makes Request_i for resources, say (1,0,2)
STEP 1: if Request_i <= Need_i
goto STEP 2
else ERROR
STEP 2: if Request_i <= Available
goto STEP 3
else suspend P_i
STEP 3: pretend to allocate requested resources
Available := Available - Request_i
Allocation_i := Allocation_i + Request_i;
Need_i := Need_i - Request_i
STEP 4: if pretend state is SAFE
then do a real allocation and P_i proceeds
else
restore the original state and suspend P_i
Banker: Resource-Request Algorithm [129]
Say P1 requests (1,0,2)
Compare to Need_1: (1,0,2) <= (1,2,2)
Compare to Available: (1,0,2) <= (3 3 2)
Pretend to allocate resources:
P0 7 5 3 0 1 0 7 4 3 2 3 0<<<
P1 3 2 2 3 0 2<<< 0 2 0<<<
Is this safe? Yes: P1, P3, P4, P0, P2
Can P4 get (3,3,0)? No, (3,3,0) > (2,3,0) Available
Can P0 get (0,2,0)? (0,2,0) < (2,3,0) Available
Pretend: Available goes to (2,1,0)
Thanks And Regards
May 13, 2009 | Microsoft Windows XP Professional
Error code 105 for casio te-2200
Hi.
We can check the memory allocation.
Turn key to program mode.
5 SUBTOTAL SUBTOTAL (must press subtotal twice).
This will print memory allocation.
Look down the printout and tell me what figures are listed under file numbers 16 and 40.
Mark
Jan 04, 2009 | Casio Parts Cash Register PC Desktop
HP Pavilion 9560ea laptop Problem: Screen intermittantly loses disply, error message states NVIDIA graphic driver problems, but driver checks confirm driver is up to date and working properly. Tried...
Hi rnb brother,
It sounds like you may need to udate you BIOS. It may be a memory allocation issue. This is an issue when the accessed/pointed memory allocation does not totally close, allowing a little bit of info out to disrupt normal operation. BIOS is closely related to access/pointed memory allocation and upon udating will close this path competely. I hope this helped a little, if not, hit me back, we have other options i.e. running dual cards.
Thank you for using FixYa.com
Sincerly cyyyd7
Oct 09, 2008 | Computers & Internet
HP DesignJet 500ps InkJet Printer Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
