Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
I can not get the drum unlatched to clean out the barrel. I am pulling the trigger but it does not open.
  • Official Brand Answer
  • 2,572 Answers
Sorry to hear you're having a problem with your DC07. You may find it useful to go through these simple steps to check everything is correct with your cleaner: http://www.dyson.co.uk/support/help.asp?article=42&product=DC07-SY
If you're still having issues, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US). We can run through some checks over the phone, and provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 09, 2011
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Rubbermaid Reveal mop trigger sticking
I bought 2 rubbermaid reveal spray mops before I figured this out. You'll need a Phillips and flat head screwdriver & a can of WD40. On the compartment that holds the liquid cleaner bottle there are 2 screws and 1 screw on the connector piece to the mop head. Unscrew all three. The one by the mop head came out and the other two stayed in their holes. Then with a flathead screwdriver gently pull the seam along the side apart. You only need 1/2-1 inch of a gap. If you pull it open all the way you'll pop a few other pieces out of place and have to piece them all back together- so gently! Then spray some WD40 in along the exposed spring using the red straw that comes with the can. Close the gap, hold it together and try the trigger a few times. If the trigger is still sticking spray more WD40 in until it frees up. Then screw your screws back in and it's as good as new!
Dec 03, 2013 | Rubbermaid Reveal Spray Mop Kit,...
Have a D4 model rainbow vaccum cleaner and want 2 no how 2 shampoo with it please help me
put cleaning solution into the proper receptacle lower brushes making contact with the surface to be cleaned. turn the on off switch on. start at the edge of the carpet squeezing the trigger for cleaning solution release and pull backwards.release trigger. roll vacuum back to begining position and pull backwards without squeezing solution release trigger. push back to the top slightly overlapping the first pass and repeat procedure. after rug is been completely shampooed allow to dry. after rug is dry sweep with broom
Feb 26, 2011 | Vacuums
My Bissell PowerEase carpet cleaner will not pick up cleaning solution. I've only used it twice.
Unlatch the cannister according to the directions, you will see a meatal latch, unhook it slide off Power nozzle, rinse it off, pull lint, hair off brushes, reassemble
Oct 19, 2010 | Bissell Vacuums
I have bissell proheat 2x 9200 no water or cleaning solution is dispensing from bottom of machine hand dispenser is not working too. how can I troubleshoot it?
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Jan 21, 2010 | Bissell 9200 Upright Vacuum
The machine turns on and the indicator seems to be spinning but the water is not moving.
Operating the trigger does not dispense water into the spinning brushes - is that the problem?
If so, remove the clean water tank and look in the opening behind the black grommet that seal the water tank. Operate the trigger and look to ensure that the valve is operating (moves downward when trigger is pulled). If it does not move, the trigger shaft is stuck or broken and will need to be repaired.
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to pull apart the cyclone barrel on my Dyson DC11
To Pull Apart the DC11 Cyclone section there are three more screws
but to get to them you need to remove the button (the one that unlocks the flap to empty the dust out) There is a small rectangular hole on the other side of the button, pushing a small screwdriver (3-4 mm jewellers ) will release the button this will reveal one of the three remaining screws , removal of the plastic section retained by this screw will reveal the remaining two
Mar 26, 2009 | Dyson DC11 All Floors Bagless Canister...
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
135 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
