Question about Hitron SEQ-324 7-Band Car Equalizer
I need the diagra for these hitro 360 peak power
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
I have a kenwood ts690s not transmitting full power
AM will only give to about 40W without modulation. This is the RF Carrier required for the AM Mode. This is because the RF Carrier is modulated by your voice, and when speaking into the mic, the voice peaks will increase the output to about 80W if not measured with a peak reading wattmeter. All radios will work like this in AM.
SSB requires audio to get any RF output. If your microphone is defective, or your MIC GAIN control is fully counter clockwise, you will get no output power when you speak into the mic. Output power, if not measured with a peak reading wattmeter will bounce to about 80W on voice peaks.
MOST wattmeters are not peak reading.
Apr 01, 2014 | Kenwood Radio Communications
I need a 110/120 volt ac/dc adapter power cord for recharging from standard wall socket. For a Peak 450 jump starter
After searching the internet for a ph number for Peak power I finally found the web.
http://www.peakauto.com/contact/site.
phone 800-323-5400
If the part department doesn't have the answer ask to be switched to tech support.
They were able to provide me with the part numbers I need for new wall supply cord and an DC adapter for the car.
My jump starter is no longer made...
Nov 15, 2013 | Peak Performance Peak PKC0BL 450 Amp Jump...
Problem with amplifier equalizer HITRON
You would be better off replacing the unit
May 22, 2013 | Computers & Internet
Fact or fiction. Are Rockford P10002 amps overrated
The efficiency of an amplifier has nothing to do with the RMS rating of the amplifier. It is true that no amplifiers are 100% efficient. The efficiency of the amplifier is calculated by how much power output it has compared to how much power it actually uses to create that output power. The RMS rating is just a measurement of the output power with no consideration of the amount of power that is needed to create that output power. Most of the high-end amplifiers are properly rated. If you see power ratings that refer to peak power, it is a little misleading. The true power of an amplifier is the RMS rating. It stands for "root means squared" but is the effective power that you hear, often referred to as the true power. It is calculated by taking the peak power and multiplying it by .707, which is always less than the peak power. When the rating of an amplifier is calculated they use a sine wave at a single frequency and it has a positive peak and a negative peak. If the power is calculated using both peaks it is called the "peak to peak" power rating. When it is calculated using only one peak it is called the "peak" power rating.
The big "con" in all of this happens when manufacturers use the "peak" power ratings instead of the "RMS" power ratings because it makes people think that the amplifier has more power when it really doesn't. Most people have no idea there is a difference in the "peak" power or the "RMS" power. It is a deceptive way of making people think that they are getting a more powerful amplifier. But none of this is related to the efficiency of the amplifier. It is theoretically impossible to make anything electronic that is 100% efficient. It always takes more power on the input than it does for the output power of anything.
I hope this answered your question, if you have any other questions feel free to ask them just by posting a response on this thread, and remember, you get what you pay for. The best amplifiers cost more for one reason, they are better. I am a big fan of Phoenix Gold amplifiers.
Dave
Sep 24, 2008 | Rockford Fosgate P10002 Car Audio...
Audiotek amp
RMS(power) = peak(power) * .707
find the peak power of your amp and use the above formula
It will have enough power to do so.
Aug 06, 2008 | Car Audio & Video
Hitron SEQ-324 7-Band Car Equalizer Logo
Top Hitron Car Audio & Video Experts
xxxxxx xxx
Are you a Hitron Car Audio and Video Expert? Answer questions, earn points and help others
