Question about Volfenhag ZX-4712 Car Subwoofer
I need to know how to hookup a volfenhag 1000w dual voice coil 12
jpenn1192
  • 58 Answers
SOURCE: how to wire a volfenhag dual coil sub
U HAVE TWO COILS ONE ONE EACH SIDE OF THE WOOFER, ALL U DO IS HOOK UP ONE COIL TO THE OTHER, THEM HOOK THEM UP TO THE TERMINALS IN THE BOX.
Posted on Oct 26, 2008
  • 45 Answers
SOURCE: is my amp powerful enuff for woofer
That amp should work fine for that sub, but you should make sure that the amp has a good power system going to it, and the box for your sub is the right one. Either one of those things could cause problems if not done correctly.
-Dynami
Posted on Apr 02, 2009
  • 150 Answers
SOURCE: best way to connect a 15
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Posted on Jan 27, 2010
SOURCE: Volfenhag ZX4725 i am buying this subwoofer and
No the LOWER the resistance the MORE Output or Draw, If say it is 100 Watts into 4 Ohms, if you used a 2 ohm speaker it would draw 200 watts.(only if capable of delivering that amount of power) The LOWER the Resistance, the HIGHER the Current Draw. WATTS = AMPS x VOLTS. (This is not strictly true with amplifiers output though, as it is an AC Current, and a "Reactive" load, it has, Inductance, Capacitance and Resistance, all in one.and is worked out via a Formula) see below. http://en.wikipedia.org/wiki/Audio_power
http://www.hometheaterhifi.com/volume_1_1/v1n1spk.html
Now with Dual Voice Coils, Essentially, you can think of these speakers as TWO speakers in ONE enclosure. As such, They are basically TWO Speakers. Please see the website below it explains everything for you. http://www.diyaudioandvideo.com/FAQ/Wiring/
Everything is a function of Resistance and Ohms law.
Current (I) = Voltage (E) divided by Resistance(R).
Voltage = Current Multiplied by Resistance.
Resistance = Voltage divides by Current.
Posted on Apr 17, 2010
SOURCE: I need to know how to wire duel voice coil 12
one way if you want to run it off 1 channel is to wire one voice coil to the other making sure +goes to +, and -goes to -,then wire your amp to one of the coils, but i found just running each coil to a seperate channel on the same amp was the best way,
Posted on May 31, 2010
How to hook up dual voice coil sub
Two things I need to know
1 Make and model of Amplifier you intend to use
2 Is it going to be a single sub or 1of a pair
May 02, 2014 | Re Audio Sxx12 12" 1000w Rms Sxx Car Sub...
Don't know how to wire a kicker solo-baric L7 2 ohm dual voice coil 12 inch sub
Wire in series for 4R. +ve of coil to amp +ve. -ve of that coil to +ve of second coil and the -ve of the second coil goes to -ve of amp.
Aug 10, 2017 | Car Audio & Video
Apr 17, 2010 | Car Audio & Video
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
Whats the best way to hook up a 12 inch dual voice coil insignia subwoofer spkr to a 4 channel 650 rev boss amp
Well without seeing a spec sheet on the amp and not knowing your voice coil impedance I will assume the following. If the speaker is dual 4 ohm voice coil the in parallel it would present a 2 ohm impedance to the amp. If this amp is stable down to 2 ohms bridged then that would be the hookup of choice. If it is not stable to two ohms with one speaker it will be tough to get full performance out of your amp. You would have to series the voice coils which would then present an 8 ohm impedance to the amp. Just look at your amp's manual before making the decision. My suggestion would be to get another one of those subwoofers parallel the voice coils on each then wire the two subwoofers in series. This would give you a 4 ohm load which your amp is almost certain to be able to drive.
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
Is my amp powerful enuff for woofer
-Dynami
Apr 02, 2009 | Volfenhag ZX-4812 Car Subwoofer
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Hooking up DVC subs
The amp is rated to run a 2 ohm load on each channel. To do this, connect the voice coils of one sub in parallel (tie both "+" on the sub to each other and both "-" on the sub to each other), then connect that sub to one channel of the amp. Repeat this process for the other sub and connect it to the other channel on the amp. The subs will be in stereo and the amp will be outputting it's maximum power.
Mar 09, 2008 | Legacy 2CH 1000W AMP Car Audio Amplifier
Volfenhag ZX-4712 Car Subwoofer Logo
181 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
