IE7 enhanced security turned on for user groups but off for Administrator group,every time I click IE it changes my home page to nag message telling me Enhanced security is turned on or off whichever the case may be. I have changed home page a thousand times but it keeps changing its driving me Nuts, How can I prevent this. Thanks
  • Anonymous Mar 23, 2014
    Causing pages to change, Slow speed, Keeps changing my home page
  • 185 Answers
Open ur system in admin priority level and then change the settings once again and restart ur computer immediately,it wl be saved.
otherwise uninstall the IE7 and re-install it again and made the same changes again.
Posted on Aug 16, 2008
Need to over ride a administrator password
Okay, this is a complicated but safe way around this.
Click start
go to turn off
and click RESTART
when your computer loads up keep on clicking F8. You will get a screen which asks you to select some options.
Only click Safe Mode or u will mess everything up
Let everything load then an Administrator icon shuld appear
Click that and click ok to any messages
Now go to control panel
Click administrative tools
click computer management
Then click on Local Users & Groups and open the folder called groups
There should be a group called Administrator
Click properties for that group
Then underneath that it should show a list of members
Click add and add the user name of the limited account
Restart your pc and go on your account and you shuld have admin priveleges
Oct 26, 2012 | Video Game Consoles & Games
Tip
Clear Windows Paging File At Shutdown
You may not consider clearing the windows paging file as a necessary part of your security housekeeping. Ok it can add quite a few seconds to your final shutdown time, but it doesn't need to be done on a regular basis and you can always disable the option as and when you want.
But why clear the paging file you may ask. Well the simple answer is security. It is not unknown for a third party software application to temporarily store unencrypted information such as passwords or other sensitive material in memory. Obviously the way Windows uses virtual memory it is possible for this information to end up in the paging file.
There are two ways of clearing the paging file. On involves Group Policy and the other the Windows registry. If Group Policy is not available on your version of Vista then proceed to Method Two.
Method One
1/ Click Start button and in the Search dialogue box type:
gpedit.msc.
2/ When in group policy window proceed as follows:
3/ Click the > button next to Computer Configuration. This will expand the menu
4/ Click the > next to the Windows settings option. Again the menu will expand
5/ Next click the > next to Security settings. The menu will expand again
6/ Now click the > next to Local Policies. The menu will expand again
7/ Now click on the Security Options
8/ The right hand pane of group policies will fill with options
9/ Scroll down to 'Shutdowns; Clear virtual memory page file'
10/ Now right click on this option and, from the menu that appears select Properties
11/ In properties click on the radio button marked 'Enabled'
12/ Now click OK
13/ Finally close group policies
Method Two: The second method can be followed using registry settings as
1/ Click Start button, followed by All Programs, Accessories and then Click the Run option.
2/ In the Run dialog box type: Regedit
3/ User Account Control (UAC) will ask permission to open Regedit. If you are the administrator, then Click the Continue button. If you are not the administrator, then you will need to ask the administrator for the administrator credentials
4/In the Registry Editor Window navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management.
5/ In the list that appears on the right of the Registry window look for the Value Name: ClearPageFileAtShutdown
6/ If the Value does not exist Right Click on the Memory Managment key and, from the drop down menu select New
7/ When you click New another drop down menu will appear. Click DWORD Value
8/ You should now see a box with the words New Value#1.
9/ Right click on this box and select Rename
10/ In the rename box Type: ClearPageFileAtShutdown
11/ After you have renamed the value, right click on it again and select Modify
12/ Change the Value to 1
13/ The registry entry should now look like this: ClearPageFileAtShutdown REG_WORD 0x00000001 (1)
14/ The changes will not come into effect until you have restarted your computer
15/ To disable the feature just reset the Value to 0
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
Forgot user account psswords
If you have forgotten your password, if you have another user account with
administrative privileges you can log into that account and change your
original user account's password from the User Accounts applet in Control
Panel. If you don't have another account like this set up or don't have the
password to it, you'll need to log into the built-in Administrator account.
In XP Home, boot the computer into Safe Mode. Do this by repeatedly tapping
the F8 key as the computer is starting up. This will get you to the right
menu. Navigate using your Up arrow key; the mouse will not work here. Once
in Safe Mode, you will see the normally hidden Administrator account. The
default password is a blank.
In XP Pro, you do not need to go into Safe Mode. At the Welcome Screen, do
Ctrl-Alt-Del twice to get the classic Windows logon box. Type in
"Administrator" and whatever password you assigned when you set up Windows.
To change the built-in Administrator account in XP Pro if you can log into
another account with administrative privileges reset the password in the
Local Users and Groups snap-in in Microsoft Management Console (MMC):
1. Click Start, and then click Run.
2. In the Open box, type "mmc" (without the quotation marks), and then click
OK to start MMC.
3. Start the Local Users and Groups snap-in.
4. Under Console Root, expand "Local Users and Groups", and then click
Users.
5. In the right pane, right-click Administrator, and then click Set
Password.
6. Click Proceed in the message box that appears.
7. Type and confirm the new password in the appropriate boxes, and then
click OK.
If you reset the built-in Administrator account's password in Home or have
Pro and don't remember the password, use NTpasswd to change the built-in
Administrator account's password to a blank.
Sep 30, 2011 | Computers & Internet
I cant install service pack3 for win xp because error 0x800a0046
Try this method
* Remove the user account that is experiencing difficulty from the Guests
or Limited account groups
Click Start, click Run, type control admintools, and then click OK.
Click Computer Management.
Expand Local Users and Groups.
Select Users.
Open the account that is used to access Windows Update.
Click the Member Of tab.
Select the user account that you want to remove, and then click Remove.;
* Add the Local Administrator and Service accounts to the Impersonate a
client after authentication policy
Click Start, point to All Programs, point to Administrative Tools, and
then click Local Security Policy.
Expand Local Policies.
Click User Rights Assignment.
Double-click to open the Impersonate a client after authentication
policy
On the Local Security Settings tab, click Add User or Group, and then
add the Administrator and Service to the list of Users and Groups.
Click OK, and then restart the computer.
good luck
Jun 27, 2011 | Computers & Internet
Hi, I'm having problem opening my backup file from my USB that I copy from my old laptop to my new laptop. When I try to open the back up file their is an error saying: unable to open file. file maybe...
you need to to take ownership of a file or a folder then copy them over
How to take ownership of a fileYou must have ownership of a protected file in order to access it. If another user has restricted access and you are the computer administrator, you can access the file by taking ownership.
To take ownership of a file, follow these steps:
  1. Right-click the file that you want to take ownership of, and then click Properties.
  2. Click the Security tab, and then click OK on the Security message (if one appears).
  3. Click Advanced, and then click the Owner tab.
  4. In the Name list, click Administrator, or click the Administrators group, and then click OK.
    The administrator or the administrators group now owns the file.
To change the permissions on the file that you now own, follow these steps:
  1. Click Add.
  2. In the Enter the object names to select (examples) list, type the user or group account that you want to have access to the file. For example, type Administrator.
  3. Click OK.
  4. In the Group or user names list, click the account that you want, and then select the check boxes of the permissions that you want to assign that user.
  5. When you are finished assigning permissions, click OK.
  6. You can now access the file.
How to take ownership of a folderYou must have ownership of a protected folder in order to access it. If another user has restricted access and you are the computer administrator, you can access the folder by taking ownership.
To take ownership of a folder, follow these steps:
  1. Right-click the folder that you want to take ownership of, and then click Properties.
  4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of the folder, select the Replace owner on subcontainers and objects check box.
  5. Click OK, and then click Yes when you receive the following message: You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?All permissions will be replaced if you click Yes.
    Note folder name is the name of the folder that you want to take ownership of.
  6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
Nov 04, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
How to setup a familyweb page on facebook>?
Basically you need to create a group.
1. When you log on to your facebook page, press the Home option on the top right of your facebook screen.
2. On the menu options down the leftt side of the screen press Groups
3. At the top of the screen press the + create new group button.
4. Follow the steps and enter relevant details.
5. Initially set yourself as the administrator of the group.
There are different options for privacy of the group and who can see the information of the group etc. See the groups help link on the groups first page (near the middle of the page)
For complete privacy the best option is "Secret: These groups cannot be found in searches or be viewed by non-members. The name of the group will not display on the profiles of members. Membership is by invitation only. Non-members will not receive stories about secret groups."
Make sure you are the Group administrator so you can adjust the settings or change the privacy/viewing options at any time by clicking "Edit Group" below the group photo after the group has been created.
Apr 04, 2010 | Facebook Social Network
Passworded user from old pc to new pc
How to take ownership of a file loadTOCNode(3, 'moreinformation'); You must have ownership of a protected file in order to access it. If another user has restricted access and you are the computer administrator, you can access the file by taking ownership.
  1. Click Add.
  3. Click OK.
How to take ownership of a folder loadTOCNode(3, 'moreinformation'); You must have ownership of a protected folder in order to access it. If another user has restricted access and you are the computer administrator, you can access the folder by taking ownership.
Source: Microsoft
Jan 21, 2010 | Microsoft Windows XP Home Edition
Cannot enable sytems restore. Message: Group
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
* Delete the value DisableConfig
* Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
More Information
Turn off System Restore corresponds to DisableSR registry value. With this Policy is turned ON, the System Restore tab may be missing in My Computer Properties. Also, when you run System Restore (rstrui.exe), you receive this message:
System Restore has been turned off by group policy. To turn on System Restore, contact your domain Administrator.
Turn off Configuration corresponds to DisableConfig registry value. With this Policy turned ON, the System Restore tab will remain displayed but the user cannot configure the SR options. It reads disabled by Group Policy.
http://windowsxp.mvps.org/srpolicy.htm
Or perhaps you can review this
Control of System Restore function has been disabled by "Group Policy".
How do regain control?Go to Start>Run, key in gpedit.msc and hit ENTER. Under Computer
Configuration, expand Administrative Templates, expand System, then click on
the System Restore folder. In the right-hand pane, double-click on Turn off
Configuration and, under the Setting tab, click in the radio button beside
Not Configured. Click on Apply then OK.
Please visit the following Microsoft Knowledge Base website
and review the topic titled: "Method 1: Use Group Policy".
How to Disable the System Restore Configuration User Interface
http://support.microsoft.com/default.asp…
Note: You must be an administrator or owner, or have administrative
privileges to perform this task.
Undo the changes using Group Policy Editor (Gpedit.msc)
-or-
Open Registry Editor and navigate to:
HKEY LOCAL MACHINE\SOFTWARE\Policies\Microsoft\Wind… NT\SystemRestore
In the right-pane, delete the value "DisableConfig".
Close Registry Editor
Close and re-open the System Restore properties page.
Note: Group Policy Editor is only Available in XP Professional (according to http://www.pcreview.co.uk/forums/thread-…
Perhaps one of these links will give you the correct solution
http://forums.techguy.org/windows-nt-200…
http://www.winhelponline.com/blog/restor…
http://www.computing.net/answers/windows…
I hope this helps you to resolve your problem.
Jan 03, 2010 | Microsoft Windows XP Home Edition
IE8 Hangs at Connecting - both Restore Session and Go Home Page
if above solution doesn't work ,try out this,
1. perform browser reset by goinginto - tools - internet options - advanced - reset.
2. if it doesn't work - get into add or remove programs - remove the tool bars, google desktop if you have installed.
Sep 22, 2009 | Microsoft Internet Explorer 8
Missing user names and groups from "Security settings" window
You have to backup all SYSTEM files and reinstall the OS. That's the ultimate solution to your problem.
Dec 26, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
