Question about Samsung TXJ2554 TV
Connecting TV to VCR but all I get is snow o n the TV
    Sergeant:
  • 217 Answers
Tune your TV to Ch 3 or 4.If it has a input button on the set or remote press it and then choose video that works with the VCR.
Posted on May 26, 2011
Getting snow when connecting polaroid tv to dish
Hi bevybab!
I would need more information as to which TV (1 or 2) you're experiencing the problem with, but if this is a new TV it sounds like you may need to change the modulator setup.
You can find the setting under Menu -> System Setup -> Installation -> Modulator Setup. If this is TV1, change the TV 1 Out to channel 3 or 4 depending on what you have listed. If this is TV2; change the mode from air to cable or cable to air and then put the TV on the channel it shows after selecting done to save the settings.
If you can provide more information or have any other questions let me know!
Tommy Faust
DISH Internet Response Team
Nov 27, 2011 | DISH Network 322 DTV Receiver
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
My jvc HR D170 ES vcr used to work fine when suddenly the picture ( snow ) is very bad but sound is ok ...tried to retune to my tv ...tried changing the rf at back ...tried tuning to my other tv and...
The vcr is fine. buy a cleaning tape. people say dry cleaner tapes wear out the heads, but it fixed my problem when my vcr only showed snow. but try a wet tape first. follow the instructions that came with the tape and run it a few times.
Jun 26, 2010 | Televison & Video
Connecting a DVD/VCR combo to LCD TV
The best suggestion I would advise is to buy a shielded scart connector & connect that from your DVD combi to either AV1 OR AV2. It sounds as if you are picking up RF interference from your current connections, this can sometimes happen if the cables do not have adequate shielding.
May 21, 2009 | LG 42LG30 42 in. LCD HDTV
Tv has snow screen but plays movies fine, just no cable channels come in clear, some one has said maybe tuner. Sanyo DS24425
It may very well be the tuner. If it has another means of connecting to the tv try composite or component cable. If that isn't possible try replacing the coax from the wall plate to tuner and from tuner to tv. This is if you have a cable box also called an STB in your home. If you do not have an STB try changing the coax from wall plate to tv. You may even want to replace the barrel on the wallplate as well. If the cable runs through the VCR disconnect it and run it straight to the tv and this will determine if the problem is in the VCR.
Hope this helps you out.
Sep 09, 2008 | Televison & Video
I broght a 32 Sharp T.V. 1080P (LC-32D62U)wroks fine. Attached is VCR(RCA) & DVD(GE) works fine except when I record on the VCR. Play back is just snow?
try channel Line 1 or Line 2 on your TV and or VCR... not channel "3" if  you're using "RCA cords".  Also, make sure your VCR and TV are "SETUP" to look for composite input's rather than coaxial.
good luck!
thomseye
May 11, 2008 | Sharp Televison & Video
TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Mar 06, 2008 | Televison & Video
My big screen tv show snow on all channels.
ok.
if you see only snow on the regular screen, might as well check the connecting antenna at the back since you mean all snow on all channels.
hope this helps.
Jan 17, 2008 | Akai PT4298HD Rear Projection Television
Reception quality
first you have to check if the problem get solve by conecting the supply sourges(cable dish or ant.) direct to the tv..if the problem get solve then try cleaning the vcr head with a liquid use head cleaner becouse a littel snow means that the problem is a littel dirty head or a broken one..also there is a chance to a mayor problen and in that case yes you have to take it to a tech...good luck if the problem persist when you conect the sourge direc to the tv then check the terminal conector if ist ok then notify you sservices company for the problem..
Aug 03, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Samsung TXJ2554 TV Logo
Henry  Thomas
Henry Thomas
