Question about Pool & Spa
I took the pump apart to change the seals. when i tested the impeller it turned freely. I put everything back to gether and now i'm just getting a hum from my motor.
  • 1,339 Answers
Ya bent,broke the start switch.. oops.. the 2 yellow wires go to the one lug on the capacitor the other lug gets the red.. most cases .. if you do a sarch in your area for pool pump motor repair with free testing.. sounds like a 20$ or less fix.. the switches are tricky on these and can get knocked out of wack easy... hey remember to prime the pump with water before you turn it on !! hope i was of help.. jay the pool pump guy in longwood fl
Posted on May 26, 2011
I removed water pump should the impeller spin freely?
no
water pumps when in good condition have a resistance to spinning freely from the load on the seal at the back of the impeller /or seal on the motor shaft and from the magnets in the field material of the motor
Nov 15, 2015 | Frigidaire Washing Machines
To replace impeller on a sls200 pool pump,does it unscrew clockwise or anticlockwise
Reverse clockwise. Make sure to replace the shaft seal when you change the impeller, or else it will leak 99% of the time. You need to stop the shaft from moving to turn the impeller. See video, impellers and shaft seals are the same how to get to the shaft in the back is not so hopefully its exposed in the back and you don't have to take it all apart.
Jul 01, 2015 | Pool & Spa
Hayward 1hp super pump-self priming -rebuilt won't run
something is binding take apart and try again
Jul 30, 2013 | Hayward Pool & Spa
Wayne irrigation pump repair manual
Sounds as though the pump is OK but the motor is not OK
May 04, 2013 | Pool & Spa
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have a Kitchenaid dishwasher KDS18. How do I replace the TANK SEAL at the bottom of the door? Do I take the door off to replace it? Thanx
It's always best to remove a door to replace a seal. Lay the door on a hard flat surface so there isn't any twist in it. Remove the old seal and install the new one.
May 13, 2011 | KitchenAid Dishwashers
I have a GE front load washer. I have had to check the filter in the bottom of the washer many times since I have had it. It has stopped draining again and when it is trying to pump we noticed that the...
This is the sign of a pump failure, the brushes in the pump motor are getting weak and this makes it hard to start the pump. Once you spin it it will take off because it had the impeller loosend before starting. I would say at the least you have bad brushes and maybe a bearing in the pump trying to seize on you. I would get a pump motor and keep it handy!
Mar 17, 2011 | GE Energy Star WCVH6260F Front Load Washer
My impeller was clogged and my pump was only humming. so i cleaned the impeller put it back together but it still only hum s its a baqua pure 2 hp pump. any advise
Check to see if the motor spins freely or appears to be dragging or stuck. If it does not spin freely, then you need to overhaul the pump and replace bearings and shaft seal or locate the source of the dragging in the pump housing
Apr 04, 2010 | Pool & Spa
Impeller does not spin freely
Pop off the half dollar sized cap at the back of the motor and use an adjustable wrench to hold the back of the shaft. They make a tool for this but with a little innovation an adjustable will do the job fine. When puting the impeller back don't tighten it more than hand tight and don't bump the motor on to seat it, this will overtighten it. You may have crossthreaded the impeller and will need to tap it out or replace it.
Jul 15, 2009 | Polaris Pb4-60 Volute Polaris Booster Pump...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
