Question about Jensen VM9424 Car Video Player
I have a new vm9424 that was put into a 2005 h2. Main problem is i can reset the time, but once i drive it for more tha a mile the clock keeps resetting its slef to a /12 hour later than it is.. nor a big problem, but one tht id just enough to really **** you off
    Problem Solver:
  • 45 Answers
CHECK THE CLOCK BUTTON SOUNDS LIKE ITS STUCK. IF ITS A TOUCH FACE SET THE TIME THEN MAKE SURE YOU GET OUT OF THAT PROGRAM AND GO SOME WHERE ELSE IN THE SYS. IF THAT DONT WORK SEND IT IN FOR WARRANTY REPAIR,
Posted on May 27, 2011
  • pink543131
    pink543131 May 06, 2012
    i had the same prob just check the daylight saving time (dst) in the miscellaneous option on the bottom of the options or check your time zone options. If that works don't feel stupid.
  • pink543131
I put new cat and sensors on my dodge ram 1500 2005 4.7,and how many miles do you have to drive before the computer resets itself
You need to do what is referred to as a drive cycle . A specific way of driving the vehicle .From a cold start till warm up , at different speeds and different conditions. Hope this helps !http://www.obd2.com/support/reprog/downloads/chrysler/chry-imset_procedure.pdf
Jan 13, 2015 | Dodge Cars & Trucks
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
Oil pressure problem
Change the oil filter. It could be clogged. That would cause an increase in oil pressure. You dont wanna blow a main seal so do it promptly. If that isnt the problem, then you might want to consider consulting a local ASE Certified mechanic to help better diagnose the problem. Good Luck.
Apr 02, 2010 | 2005 Hummer H2
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
PLEASE HELP
I'm sure anyone with an OBD reader can reset the warning for you you. Also you could search the Hummer forums to see if anyone has fix for this.
Aug 12, 2008 | 2005 Hummer H2
Jensen VM9424 Car Video Player Logo
189 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
