Question about Alpine MRP-M650 Car Audio Amplifier
My Alpine MRP-M650 Amp is acting up. When I start the car, if the volume is at low, the subs don't work. But when I turn up the volume, they eventually kick in, then I can lower the volume. But when I turned the engine off and restart the car, the same problem happens again. RCA Cable works fine and I tried this with a different amp and everything works fine. What could be causing this?
    Sergeant:
    Novelist:
  • 159 Answers
There are a lot of things that could cause this issue ...
1. Your amp requires more power than it gets when you start your car, and needs to charge up before it can work. If this is the case, you should be able to give your stereo about 5 minutes to warm up at low volume and it should come on. This happens a lot with amps with built-in capacitors (capacitors give you stunning, instant kick when working, but require a bunch of power to initialize). If you wire a bypass switch for the power to your amp and bass components, you can turn it on separate from the rest of the car and allow it to charge before you start your car (just be careful to turn it off when you are going to be away from your car for a while since this will allow your system to drain your battery).
2. Your amp might be set incorrectly for handling the system you are running. If your Ohms do not match up exactly (8 ohm speakers with a 4 ohm amp -- it's the "Impedance rating") then the system should not work at all, or should burn out the amp ... but with a jury-rigged system it can work. If this is the case, I recommend getting a new amp that matches your speakers.
3. Depending on the amp, there might be a volume-based cutoff that is working improperly. Turn on the car with the stereo at low volume. While the speakers are still not working, check to make sure that the amp has power, and seems to be functioning correctly. If everything seems like it's on the up and up, but the speakers are not working, try changing the volume-filter options on your amp.
4. I put this last because it seems like you know what you are doing with the system setup, but it is possible that you have a bad connection between the speakers and the amp, or between the stereo and the amp. There could be a loose connection somewhere (either inside the amp, between the amp and the speakers at the jack, or between the stereo and the amp at the jack). If this were the case, everything would look perfect from a visual inspection, but there could be a tiny space, or corrosion in a connection. Turning the stereo up to a high volume could then bridge this short circuit, and the electric force could magnetize the connection shut, allowing you to then turn the stereo down with the working connection. The best-case scenario here would be an external wiring issue, where you can clean any corrosion off the connections with an eraser, and reconnect everything tightly fixing the problem. The worst case would be a short WITHIN the amp, which would have to be repaired by someone with a lot of time and a circuit tester -- in which case you might be better off trading the amp in for a new one.
Posted on May 26, 2011
Testimonial: "Thank you so much for a super fast response! I will check the things you mentioned and hopefully find a solution!"
  • vaxjjangu May 26, 2011
    I think it's safe to say that #4 is not it. Maybe something's wrong within the Amp, but not the other cables and connections since it worked perfectly fine with a different amp.
    #2 shouldn't be it, since I have 2 10" Alpine Tyse S's 2ohms with this amp which can power 2ohms and 4 ohms.
    I think it could be #1 & 3. This is only a 600watts amp though, do you think I will need a capacitor?
  • Dave
    Dave May 26, 2011
    A capacitor will give you more punch in your bass, but it is usually not necessary unless you are running a 15" or larger sub, or an unlimited competition system. Basically, a capacitor just stores a bunch of extra energy to give the sub-woofer instant, full power at the coil, but if your system is running off an amp and you are satisfied with the sound you are getting it shouldn't be needed.
    If you have gone over everything, and the problem is still happening, I would think that it is a miniature short within the amp somewhere. These things happen (it's why I don't have a system at the moment) and tends to be an early-warning sign that the amp is going to die if it does not get repaired quickly. It is possible to fix it yourself if you have a circuit tester and a bunch of free time -- just open the case and check the continuity of each of the connections. I would start with the connections closest to the speaker jacks and work your way across the circuit board. This takes a significant amount of time, unless you happen on the problem early, but it can save you a lot of money if your amp was expensive. The problem with this is that the circuit tester itself might close the short circuit while you are testing the line ... so there is no guarantee that you will ever find the problem -- which is (once again) why I do not have a system in my car.
    As far as working 2 10" speakers with a 600Watt amp, as long as the impedance rating and amperage are matched, you should be fine. You can run a speaker that will accept more watts than the amp puts out without a problem if the other things are matched up, but you'll blow your speakers if you try to run a high-output amp through low input speakers even if everything else is matched.
Check the two large power supply capacitors for signs of puffing. Chances are, they are discharging when you cut remote power. When power is applied, they need an extra bump from your low level inputs to charge and fire. I believe these are 35V 8200uf 20% tolerance caps.
Posted on Sep 26, 2012
My mrp m650 alpine amp power light is on but no sound. it works if i hook it to other vehicles but not in mine.
Check your speakers and speaker wires to make sure you have no shorts or grounds. Not knowing what vehicle you are putting the amp in, there is also a possibility that there may be a stock amp in the vehicle. If this is the case, you may have to rewire the speakers and bypass the stock amp.
Feb 27, 2012 | Alpine MRP-M650 Car Audio Amplifier
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
When i turn my alpine MRP-M650 amp on there is a click in the sub and then nothing else. when i was driving with volume down low the sub just stopped working.
sounds like a short. did you check the amp fuse and the fuse on the power wire (under the hood) make sure there are no wires touching. most common is the wires to the sub touching on the amp. let me knwo if that helped
May 17, 2011 | Alpine MRP-M650 Car Audio Amplifier
Amp slow to kick bass in.
it sounds like you havnt got the memory live conected on your hea duit or it is conected to an ignition live this is no good it needs to be conected to a permenent live to ensure the memory has power at all ties of it coulb be that the amp needs adjusting for low volume use
to set up a sub you turn up the volume to the required level then adjust the amp acordingly hope this helps ben
Oct 11, 2009 | Alpine MRP-M650 Car Audio Amplifier
Subs dont work when base is up high
Sounds like the amps needing more current available to it-You should have 4 gauge power coming off the battery going into a distribution block from there a 4 gauge to a 1 farad capacitor off the block -4 gauge to the ground for the capacitor -and two + leads from the block to your amps-you would do well with 6 gauge there.- That is to ensure that you have plenty of power on tap when needed and not trying to draw it off your charging system on heavy current demands.Make sure that your grounds are well placed and solidly connected. As for putting 600+watts on a pair of 8z......i hope that they are the CVR or the L5 / L7 series to take that much power,I've seen it done and the ones i heard sounded badass(L7 series)-but that was at the stereo shop so they had they stuff on HITTN status up in there. If your running the "cvr" or the "comp" series you might be throwing too much power on them -might want to step up your subs to a set of 12s just to get more air moving in there- good luck
May 28, 2009 | Alpine MRP-M650 Car Audio Amplifier
Problems with MRP-M650
as far as it staying on it may have been wired to your hot unstead of your remote on your radio
when it runs wide open it gets hot
how are your gains
I have an alpine and I just hooked up jl 12 w3s and it kinda j did what yours did
it played.. hit hard then no subs.. my mids and highs platyed, but until I would turn off the car and restart the radio the subs immediately came on and the subs are only connected to this aplpine mrp m 650 amp
what speakers and what ohm did they wire it too?
i think my problem was I was overloading my amp feeding it a 2 ohm load or a one ohm load and it was shutting down my subs.. protectection I suppose?
Jun 02, 2008 | Alpine MRP-M650 Car Audio Amplifier
MRP-M450 puts out no sound to the subs
The amplifier may be overloaded, check to see if it can handle 4 OHM loads and 2 OHM loads. if it turns off at high volume the amp may be overloaded. if so try a 8 OHM load. if it still turns off it may be an internal problem.
Jan 07, 2008 | Alpine MRP-M650 Car Audio Amplifier
Alpine mrp-m650 amp cutting out
Some AMPs have a thermal cutout, that switches the amp off if it gets too HOT.
But this sounds like your amp or sub is screwed, either there is to much resistance in your sub, eg: Burnt voice coil, carbon builds up on the coil stopping the sub from moving freely. Push on the cone of the sub & listen for a scrapeing sound.
or test this by continuity testing the sub terminals & pushing the cone if the BUZZER on the MultiMeter cuts in & out as you push & release then your sub is screwed. ( a certain amount of repeatative pushing it may free up the voice coil.)
or your Amp may have blown a internal fault that will have to be sent of for repair.
Or you have a incorrectly rated fuse for your system,
or the battery cant kope with the power surges???
THIS DOES NOT APPLY TO YOU AS YOU HAVE A POWER-CAP!!!
Dec 19, 2007 | Alpine MRP-M650 Car Audio Amplifier
Alpine MRP-M650 : Power LED turns on but no sound. All the connections are made. Subs have been tested on another amp.
is the remote lead properly connected to the head unit? if the power led is on then the power cable and earth must be good, check the remote lead 2 your head unit first, if thats all good try looking at the amp to see whether theres a small switch to adjust the output going to the subs, if its very low or right off then nothing will be going through to the subs. if its on high and fine it only realy leaves the neg and pos inputs from the amp 2 the subs.
cheers, adam
Oct 30, 2007 | Alpine MRP-M650 Car Audio Amplifier
Alpine MRP-M650 Car Audio Amplifier Logo
326 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
