Question about LG C 2200 Cellular Phone
Charging handset is off. what does that mean?
  • 73 Answers
Phone power was off while its charging.
Posted on May 26, 2011
WHAT DOES THE READOUT =BASE= MEAN
Remote handsets must be synchronized with the base unit. The remote charging stand will not perform this function. If the handset goes dead or the battery disconnected and reconnected, you must return the handset to the base unit and cradle it so it can be identified and synchronized to the base unit.
Mar 06, 2015 | Lands Phones
Red light at top of handset blinks constantly
If that means, "charging," then it's time to replace the battery pack...
Mar 09, 2014 | Uniden DECT 6.0 Cordless Phone ID
DECT 1480-4 Uniden Corless phone- how do you get rid of red LED lite ?
Do you mean the status light on the handset or the one on the base? The status light on the base will be on if the answering system is on. The handset status light will be on but steady when the handset is on the charger. (It's a battery charging indicator in that case; take the handset off the charger to stop the charging system. It provides a trickle charge to offset the battery discharging over time) The light blinks to indicate new messages are available on the answering system. Press the Play button on the base or the Messages/Mute button on the handset to play new messages.
Uniden offers the manuals for many of their phones on their support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The direct link to the manual for the DECT-1480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf .
I hope this helps.
Dec 02, 2011 | Lands Phones
Nokia Charging Problem
Hi, this is what you do when your phone refuses to charge..
WHEN YOU'RE HANDSET REFUSE TO CHARGE.
1. Read the battery charging terminal if it is continually. 2. Read the board interface if it continually on the charging interface. 3. Read the charging put on continuity if it is continually. 4. If they are all contacting, still not charging, then you service it by W/H i.e. washing and heating. 5. If not still charging, you trace the charging interface with another board by means of looping.
REMEMBER: The process by which you connect a tinny copper for an external construction, or a unit interface which is known as looping. 6. If it does not charge it them means that the charging IC is bad.
ALTERNATIVELY: You may advice the person to buy a universal charger or desk top charger and extra battery for a better charge.
Feb 21, 2011 | Nokia 6300 Cellular Phone
My 8230 phone will not turn on put battery in and
A red light on a blackberry means the battery is flat. (Requires re-charging)
If you are confident your battery is FULLY charged and your charger is working then you may need to take your handset to a repair shop.
Try charging up the battery whilst in the handset. Let it charge for 30 mins then try and switch it on.
Remember...Blackberry handsets take longer than most to start up.
Jul 05, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
When i am charging my motorola mobile the display comes like ''UNDER TEMPRETURE'' means what.
When charging any phone and it indicates: Under temprature, it simply means the charging point or the charger might have gone bad.
Please get another charger to trouble-shoot, if this does not stop it then let an expert confirm if the chrging point of the handset is bad.
Good luck and rate this too.
Jul 29, 2009 | Cell Phones
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
LG C 2200 Cellular Phone Logo
557 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
