Question about Pioneer DEH-P730 CD Player
I have an old pioneer DEH-P730 deck that i am trying to install and when i plug it in and turn it on it just goes beep .... beep ... over and over is it the deck or a problem with the wiring ?.
  • 3 Answers
SOURCE: Wiring Diagram Pioneer DEH 45x4
Well first you will have to get the fit kit for your car to prevent the radio from being stolen, and make it fit right. you can get this part at Best Buy, Circut City, or even sometimes at walmart. also you will need to get the proper wiring harness. all you have to do is go to an audio place and ask them for the proper parts for your car and they will get them for you. After you have everything that they say you need all of the wires match up colors. extra wires you will have is the remote wire witch is blue w/white stripe. and an orange one (illumines) witch if isnt on the wiring harness for your car its fine. all the ill. wire does is dim the radio when you dim your other componets in your car.
Posted on Feb 03, 2008
SOURCE: What wiring harness and deck install kit?
My husband and I just installed a Pioneer DEH-2000 MP today in my 2004 Sentra, which we bought at Electronic Express. They didn't have the wiring harness or the install kit we needed, but Best Buy did. Just go there or some other electronics/car audio place and tell them what vehicle you are installing your stereo into. Make sure you do have all the same color wires and numbers of them on your harness(s) as you do for your stereo - they should of course match, and the plugs of the harnesses will match those of your truck. Don't freak out if you don't use all the plugs in your truck though - one may be left because it was proprietary to your stock radio. A couple of good install kit brands are Scosche and Metra - both use factory colors and molding that will match the color and lines of your dash to make it look as integrated as possible.
Hope that helps!
Posted on May 27, 2008
  • 87 Answers
SOURCE: wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 02, 2009
  • 306 Answers
SOURCE: i need a wiring color code for a pioneer deh p6400
constant is yellow . switched ignition is red. ground is black. amp remote is blue white. illumination is orange. speakers are gray front right. white is front left. green is rear left. purple is rear right. all speaker wires have a match with a black stripe.black stripe is negitive
Posted on Feb 07, 2010
bcfr820
SOURCE: pioneer DEH-17 wiring diagram or pinout connection
the groung wire was torn out of my deh1700 pin connector where does it go back
Posted on Aug 25, 2011
The security code for my pioneer deh-p6500
This deck doesn't come with a secuirty code installed, the 1st owner must install the code, so there is no way to know what that code may be. Are you the 1st owner? Call Pioneer and see if there is a way to get around this problem. They may ask for proof of ownership.
Jan 18, 2012 | Pioneer DEH-P6500 CD Player
What color wire from deh-4600 pioneer deck goes to power ant?enna
The Blue / White colored wire is used to operate an electric antenna relay or the external amplifier.
You can download either or both the User Manual or Installation Manual for free (that's where I found your info) here.
If my answer was helpful, please rate as such. Thanks & good luck!
Oct 14, 2011 | Pioneer Deh-p4600mp
How to set clock on deh-p730 pioneer car stereo
For most older Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears.
    *With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Apr 20, 2011 | Pioneer DEH-P730 CD Player
I lost the manual to install my stereo pioneer DEH - 23ub
go to store that sells car decks and look for a wiring harness for ur car its about $7 mybe and prettymuch match the colors on ur deck to the harness and then pull ur old deck out and pull the harness from the back the back of that deck and plug that into the wire harness u just bought and hook up the antenna for radio andput the deck into the dash the wire harness should also come with so directions too just in case
Apr 16, 2011 | Pioneer DEH-P2900MP CD Receiver...
Pioneer deh p3100ub shuts off when i touch deck
sounds like the faceplate is not seated right or has dirty connections but it is in your detachable face plate. your still under warenty.
May 24, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Pioneer Deh-2000 cd changer wiring schematics
here is the link to the manuals for your deck:
http://www.pioneer.co.uk/uk/support/manuals/DEH-2000MP/index.html
see installation manual page 4 for the wiring diagagram
Cheers!
Nov 11, 2009 | Pioneer DEH-2000 CD Changer
I don't know how to wire this pioneer deh-p2900mp
the wires will not be the same. the best thing to do is go to the nearest place where they sell radios and they do have to sell the two plugs that have the same wiring diagram as the radio and then direct connect to the two plugs on the car.
Sep 11, 2009 | Pioneer DEH-P2900MP CD Receiver...
DEH-P7800MP
You can get replacement wiring harnesses from Pioneer (www.pioneerelectronics.com) or from a local stereo shop that sells Pioneer product. Also, check Ebay...there are often times harnesses for sale for any model of radio from all across the country.
Aug 10, 2008 | Pioneer DEH-P7800MP
Pioneer Premier DEH-P730
Pioneer follows standard color coding for stereo/headunit wiring. Pioneer car stereos needs two wires plus the ground wire to be activated. The yellow is connected to the always on B+12 such as the positive terminal of the battery, the red goes to a switched B+12 such as the ACC of the IGN switch while the black of course goes to the chassis/body ground.
Should the above been done correctly and problem persist, then perhaps the fuse may have blown, there is a loose connector at the rear of the head unit or a probable internal electronic defect has developed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Pioneer DEH-P730 CD Player
Pioneer deh p730
Has it always been like this? I know that the display inverts automatically to save the life of the OEL...otherwise the brightness of the same pixels being on all the time will cause the OEL to 'burn-in' If that isn't the problem, the OEL is going bad. They can run about $100 and usually aren't worth repairing.
Aug 14, 2006 | Pioneer DEH-P730 CD Player
Pioneer DEH-P730 CD Player Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
