Power problems I am having problems with power to my laptop. When I plug in the power plug, it shows that I am using the battery, when in fact I am using power. Sometimes it will show that i am using power but if I move at all the battery meter comes on again. Can you please tell me what the problem may be so i can get it fixed. Thank you so much
  • 2 more comments
  • lilees Aug 16, 2008
    HI there,
    thank you so much for your advice. I am sorry if I sound naive, but you do mean the connection on my laptop is the problem, and not the power box itself. As you can see, I am a female LOL
    If it is indeed the computer I shall have to take it to a tech so they can correct the problem.
    Thanking you once again :-)
    bye and thank you again
  • Anonymous Dec 12, 2008
    Did you get this fixed? I have the same problem and even the slightest movement (sometimes just typing) or no movement at all, the power toggles back to battery. My battery is so weak it only lasts about 5 minutes so I have to always pay attention. It is quite annoying. I know it's the connection and would have to open the computer to fix it. I just wonder if it is fixable in the first place before going to the trouble and costs of a computer tech.
  • nick541 Apr 15, 2009
    My HP Omnibook xe3 has a broken connection from the power jack to the motherboard. I purchased an external battery charging lead which is fine as I had a spare battery anyway. I really need continuous AC power though. Can this be fixed premanently?
    Champion:
  • 214 Answers
Hi, it seems there is some loose connection in the power supply section. open and find any power connector loose/ fix all connectors gently.
thank you
Posted on Aug 16, 2008
  • Rabby V V
    Rabby V V Aug 16, 2008
    hi, thanks for the response. You need to open the laptop to correct the problem, and as you mentioned take the help of a computer tech.
    ok, bye
Asus K52jc-sx022v
One possibility is that the plugs where the battery is attached are scr...d up. Try to check them and see if there is any obvious problem... If not, there might be a short-circuit somewhere near the battery (in the laptop, not in the battery..)
Jan 26, 2014 | Computers & Internet
Compaq pressario f500 power supply not working while laptop is powered on, yet charges when off
Check that the power supply is the correct one for the laptop. It sounds as if the supply doesn't have enough power to supply the laptop (Watts)
Nov 03, 2012 | Computers & Internet
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Mine is a Sony VAIO VGN CR353 Laptop. I have a problem my laptop doesn't boot with battery in also It shows a message on the battery on as "Plugged In Not Charging". I tried many ways to...
How do you know it is not a battery problem? It seems obvious that the charger is working as the message you get tells you it is getting power to the laptop. So it looks like the solution is to get a new battery, also indicated by the fact that you can't boot with the battery in.
Oct 29, 2017 | Sony VAIO VGN-T370P/L Notebook
Advent Roma 1001 laptop. Turning on the laptop via the mains supply, the laptop springs to life and have no problems. The battery icon shows 100% charged and the battery l.e.d. light glows blue. Turn off...
The fact that the laptop is recognising the battery's presence and yet is not receiving any power from it is not a good sign I'm afraid. There are batteries available online for around £40 but you may want to take the laptop to a repair centre first where they can usually tell you (for around £7-£10) if it is definitely a battery malfunction or not before you splash out on a new one.
Sorry I can't be any more help, battery issues are usually pretty black and white, they're either broken or working. Hope you manage to get it sorted either way.
Jan 17, 2011 | Advent Netbook
Hp laptop will not power up...at all. In fact the
1) You need to check the power supply itself to mkae sure it still puts out the DC voltage as indicate on the power supply.
2) You may have cracked solder joints at the DC input jack of the laptop.
look here for more info: www.insidemylaptop.com
Oct 26, 2009 | HP Pavilion dv9000z Notebook
Dell Inspiron 6400 Battery not charging
It is more then likely a battery problem I'm affraid! Some folk will pass on 2nd hand batteries which are faulty on ebay. The chargers very rarely go wrong, but because there usually a sealed unit the only sure fire way to eliminate the charger from the problem is to test it on another computer or appliance with the same power socket, or possibly test it with a multimeter and make sure the correct voltage is being passed through. It may be a good idea to take the computer with both batteries to a local computer store to see if they can test them both and the charger, to doubley make sure. Some places will often do this for free.
Rich
Aug 15, 2009 | Dell Latitude D600 Notebook
Problem with distrubing power to my HP dv6700 laptop!
You may have more than a dead battery problem, but possibly a problem with the ac adapter or the internal psu. Does this only happen with you try to use the laptop with the battery removed? or does it fail to turn on with or without the battery snapped in?
Jun 09, 2009 | HP Pavilion dv6000z Notebook
Toshiba Laptop Computer model m45-s265 no power
I would suggest draining the residule electricity from the system and then try switching it on again.  Follow these steps:
  1. Unplug from any power source.
  2. Remove the battery (you will have to flip the laptop upside down and find the lock button that holds the battery in before you can slide it out).
  3. With the battery removed and the power disconnected, tap the power button on the laptop.  Nothing will appear to happen, but in actual fact any residual electricity that has built up across the motherboard will drain.
  4. Plug back in and try switching on again.  If it works, plug the battery in and you're back in business.
If the system still does not work after this, take it in to a repair shop or call your laptop's support service to get more advice, as it could be the motherboard.
Nov 06, 2008 | Computers & Internet
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
