Question about Audiovox (CE256) Clock Radio
We have an Audiovox Model AXCR550 clock radio that gains about one and a half hours in 24. Is there any adjustment for this?
Setting the Sharp atomic clock SPC315
Sharp SPC315 Clock Setup Instructions
Set Time Hours and Minutes:
Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Adjust/Channel button to change the hour.
Press the Time/12/24 to go to minute
Press the Adjust/Channel button to change the minute.
Press the Time/12/24 to set.
Set Alarm1 and Alarm2:
Press the Alarm1/Alarm2 button to toggle either Alarm1 or Alarm2 to set.
Pres the Alarm1/Alarm2 and Alarm2/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Alarm1/Alarm2 to go to minute
Press the Alarm1/Alarm2 to set.
Set Calendar Year:
Press Calendar/C/F and Max/Min buttons at the same time for two seconds and it will start to blink the calendar year.
Press the Adjust/Channel button to change the year.
Press the Calendar/C/F to go to Month.
Press the Adjust/Channel button to change the Month.
Press the Calendar/C/F to go to Day.
Press the Adjust/Channel button to change the Day.
Mar 01, 2015 | Sharp Atomic Weather Station Alarm Clock...
Ho do I keep my Dunhaven Mantelclock from gaining time
Watch this interesting video about
Dunhaven Mantelclock www.youtube.com/watch?v=jFcUXJ8iv8g
Feb 06, 2015 | Home
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
I have the 444100 model and for somw reason i see
to change the clock from 24 hour time to regular am, pm time, all you have to do is press and hold the "up" button. it should change back to regular 12 hour time.
Oct 29, 2009 | Equity Time USA Sky Scan 44100 Clock Radio
How do you set the clock for 12 hr time, not 24 hour ??
On most clock radios, there is a Time button. Usually, just hold it down while adjusting the Hr. or Min. I have not seen too many clock radios that do not use that kind of setup.
Oct 28, 2009 | Audio Players & Recorders
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
Nov 26, 2017 | General Time Corporation Westclox Bell...
Problem with time staying
From Brother Support Website.....
PPF4100 (Clock Gains ½ hour)
The LCD clock on the PPF4100 gains a half hour every 24 hours. Units affected were manufactured between January 2004 and April 2004. The machines manufactured after s/n D4J419125 have the new firmware already installed from the factory.
Machine will need to be taken to a service center and have a firmware upgrade done.
Inkworks
866-381-0541
Nov 04, 2008 | Brother IntelliFAX 4100 Laser Fax
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Bose Wave Radio CD clock gaining two hours a day.
I have the opposite problem (110v radio but 220v power). Like to exchange the power supply?
Nov 13, 2006 | Bose Wave Radio
Audiovox (CE256) Clock Radio Logo
71 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
